Author Topic: Showing year as three digits!  (Read 321 times)
Hi everyone,
This line has caused the year to be shown as 3 digits, (201). Could someone put me out of my misery and show me how to do it. The rest of the line works fine.
chars = sprintf( test, "%02d:%02d:%02d   %02d:%02d:%04d   ", hour(), minute(), second(), day(), month(), year() );
I changed the  %02d to %04d but this made no difference.
New Jersey
Looks fine. Post the entire sketch for more help.
Austin, TX
CMiYC
Yes, need to see the whole sketch.  Specifically how test and chars are defined and how you are using them.  Also, what is creating these functions you are getting the data from.
www.cmiyc.com - A guide to being an Enginerd
Thanks for your prompt replies, here is the code:
MSFTime MSF;// = MSFTime();
time_t msfTimeSync();
byte prevStatus = 255;
void setup()                    // run once, when the sketch starts
  LedSign::Init(GRAYSCALE);
  MSF.init( 255 ); // LED pin for status
  setSyncProvider(msfTimeSync);  // tell the Time library what to ask for a new time value
time_t msfTimeSync() // called periodically by Time library to syncronise itself
   return MSF.getTime();
void drawLine( int offset, int val, int range )
  int total = 9;
  val = val%range;
  int at = ( val * total ) / range;
  for( int i =0; i < at-1; i ++ )
    LedSign::Set(i,offset, 1);
  LedSign::Set(at-1, offset, 3);
int offset = 13;
void loop()                     // run over and over again
  LedSign::Clear();
  //drawLine( 0, 7, 8);
  char buff[20];
  now(); // make sure Time has attempted to sync
  byte currStatus = MSF.getStatus();
  #define MESSAGE_LEN 20
  char test[MESSAGE_LEN];
  int chars =0;
  if( timeStatus() == timeNotSet )
     if( ! (currStatus & MSF_STATUS_CARRIER))
       chars = sprintf( test, "NO CARRIER   ");
     else if( (currStatus & MSF_STATUS_WAITING))
       drawLine( 8, MSF.getProgess(), 60 );
       chars = sprintf( test, "WAITING   ");
     else if( (currStatus & MSF_STATUS_READING))
       chars = sprintf( test, "READING   ");
       chars = sprintf( test, "CONFUSED   "); // should never happen
    int mins = MSF.getFixAge()/60000L;
    if( mins < 0 )
      mins = 0;
    drawLine( 8, mins, 14 ); // fix age, one LED per min
  int8_t x, x2;
  x = offset;
  for(int i=0;i<chars;i++)
    x2=Font::Draw(test[i],x,0,3);
    x+=x2;
    if (x>=13) break;
  if( x >= 13 )
    offset --; // there was more stuff to draw off the right, keep scrolling
    offset = 13; // set the scroll back to draw at the right of the screen
  delay(80);
« Last Edit: July 26, 2012, 01:11:48 pm by picmetoo » Logged
Copenhagen, Denmark
Have you testrun your PDE file today?
You MUST enclose your code in the code tags (use the "#" icon when entering the code). For example: I see a smiley with sunglasses suddenly in the code instead of a digit and closing bracket. I can guess this is a 8. Also some subscript brackets get "swallowed". Note you can edit the post you have submitted.The above was edited, so now legible.
You're also missing the "#include" of the libraries you are using.
« Last Edit: July 26, 2012, 02:00:19 pm by Msquare » Logged
Austin, TX
CMiYC
You defined test to be 20 characters long.  Sprintf() puts a null character at the end, which takes up a character.  Test needs to be bigger.
I'm not sure I understand what you are doing with the variable "chars".  sprintf returns the number of characters written.  "chars" isn't an int, it is an array of characters, why?
Thanks James C4S,
I Increased it to 30 characters and it works fine.
