Topic: how to generate an asm program listing (Read 8571 times) previous topic - next topic
jahronchek
Jul 27, 2012, 01:33 pm Last Edit: Jul 27, 2012, 01:36 pm by Checkers1811 Reason: 1
I need to have an assembler program listing for my Arduino project. I've looked in the build folder and can find only the object code there, with the .hex files and other support files of course.
Does anyone know how to modify the Windows Arduino 1.0.1 IDE to output assembler listings for all compiled source files?
johnwasser
I don't think there is a way to change the avr-gcc switches without the java source code and re-building at least one of the .jar files in the IDE.
The AVRgcc tools that come with Arduino include two programs for dis-assembling binaries.  Read about avr-objdup and avr-readelf.
You can learn to use the avr-gcc directly.  That way you can provide it with any command-line switches you want.  The easiest way is to turn on verbose logging for the build and look at the command lines that Arduino generates.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
jahronchek
Can you tell how to turn on verbose logging?
dxw00d
It's in preferences, unless you are using a Pre-1.0 IDE.
jahronchek
I am still using 0021, but am attempting to move to 1.0.1
I havbe an urgent need to solve a problem and no time to get to 1.0.1 before that is done.
So, I am stuck here for now.
dxw00d
Hold down the shift key when compiling/uploading for verbose on Pre-1.0 IDEs.
MichaelMeissner
In addition, if you are invoking avr-gcc directory, there are the following options:
  • -save-temps -- when compiling, leave .ii and .s files around (.ii is the C++ source after the preprocessor, .s is the assembler file)
  • -Wa,-al -- tell the assembler to generate a listing file to standard output
Coding Badly
Thank you!  I need that!
MichaelMeissner
Yes, I added -save-temps many, many years ago (probably about 22 or so), as it made tracing down problems in large builds much easier, in that you could just look at the .s file or feed the .i/.ii file into the compiler to debug it.
In the last 2-3 years, there have been some warts, when we moved the preprocessor into the compiler, and I added support to turn on particular processor options for given functions, but over all, -save-temps is useful.
DuaneB
Would an objdump do or are you looking specifically for .asm ?
sample objdump of digitalRead in all its 'I never knew it was that big' glory -
Code: [Select]
int digitalRead(uint8_t pin)
uint8_t timer = digitalPinToTimer(pin);
    1342: 68 2f        mov r22, r24
    1344: 70 e0        ldi r23, 0x00 ; 0
    1346: cb 01        movw r24, r22
    1348: 82 55        subi r24, 0x52 ; 82
    134a: 9f 4f        sbci r25, 0xFF ; 255
    134c: fc 01        movw r30, r24
    134e: 24 91        lpm r18, Z+
uint8_t bit = digitalPinToBitMask(pin);
    1350: cb 01        movw r24, r22
    1352: 86 56        subi r24, 0x66 ; 102
    1354: 9f 4f        sbci r25, 0xFF ; 255
    1356: fc 01        movw r30, r24
    1358: 44 91        lpm r20, Z+
uint8_t port = digitalPinToPort(pin);
    135a: 6a 57        subi r22, 0x7A ; 122
    135c: 7f 4f        sbci r23, 0xFF ; 255
    135e: fb 01        movw r30, r22
    1360: 94 91        lpm r25, Z+
if (port == NOT_A_PIN) return LOW;
    1362: 99 23        and r25, r25
    1364: 19 f4        brne .+6      ; 0x136c <digitalRead+0x2a>
    1366: 20 e0        ldi r18, 0x00 ; 0
    1368: 30 e0        ldi r19, 0x00 ; 0
    136a: 3c c0        rjmp .+120    ; 0x13e4 <digitalRead+0xa2>
// If the pin that support PWM output, we need to turn it off
// before getting a digital reading.
if (timer != NOT_ON_TIMER) turnOffPWM(timer);
    136c: 22 23        and r18, r18
    136e: 51 f1        breq .+84      ; 0x13c4 <digitalRead+0x82>
//static inline void turnOffPWM(uint8_t timer) __attribute__ ((always_inline));
static void turnOffPWM(uint8_t timer)
switch (timer)
    1370: 23 30        cpi r18, 0x03 ; 3
    1372: 71 f0        breq .+28      ; 0x1390 <digitalRead+0x4e>
    1374: 24 30        cpi r18, 0x04 ; 4
    1376: 28 f4        brcc .+10      ; 0x1382 <digitalRead+0x40>
    1378: 21 30        cpi r18, 0x01 ; 1
    137a: a1 f0        breq .+40      ; 0x13a4 <digitalRead+0x62>
    137c: 22 30        cpi r18, 0x02 ; 2
    137e: 11 f5        brne .+68      ; 0x13c4 <digitalRead+0x82>
    1380: 14 c0        rjmp .+40      ; 0x13aa <digitalRead+0x68>
    1382: 26 30        cpi r18, 0x06 ; 6
    1384: b1 f0        breq .+44      ; 0x13b2 <digitalRead+0x70>
    1386: 27 30        cpi r18, 0x07 ; 7
    1388: c1 f0        breq .+48      ; 0x13ba <digitalRead+0x78>
    138a: 24 30        cpi r18, 0x04 ; 4
    138c: d9 f4        brne .+54      ; 0x13c4 <digitalRead+0x82>
    138e: 04 c0        rjmp .+8      ; 0x1398 <digitalRead+0x56>
#if defined(TCCR1A) && defined(COM1A1)
case TIMER1A:   cbi(TCCR1A, COM1A1);    break;
    1390: 80 91 80 00 lds r24, 0x0080
    1394: 8f 77        andi r24, 0x7F ; 127
    1396: 03 c0        rjmp .+6      ; 0x139e <digitalRead+0x5c>
#endif
#if defined(TCCR1A) && defined(COM1B1)
case TIMER1B:   cbi(TCCR1A, COM1B1);    break;
    1398: 80 91 80 00 lds r24, 0x0080
    139c: 8f 7d        andi r24, 0xDF ; 223
    139e: 80 93 80 00 sts 0x0080, r24
    13a2: 10 c0        rjmp .+32      ; 0x13c4 <digitalRead+0x82>
#if defined(TCCR2) && defined(COM21)
case  TIMER2:   cbi(TCCR2, COM21);      break;
#endif
#if defined(TCCR0A) && defined(COM0A1)
case  TIMER0A:  cbi(TCCR0A, COM0A1);    break;
    13a4: 84 b5        in r24, 0x24 ; 36
    13a6: 8f 77        andi r24, 0x7F ; 127
    13a8: 02 c0        rjmp .+4      ; 0x13ae <digitalRead+0x6c>
#endif
#if defined(TIMER0B) && defined(COM0B1)
case  TIMER0B:  cbi(TCCR0A, COM0B1);    break;
    13aa: 84 b5        in r24, 0x24 ; 36
    13ac: 8f 7d        andi r24, 0xDF ; 223
    13ae: 84 bd        out 0x24, r24 ; 36
    13b0: 09 c0        rjmp .+18      ; 0x13c4 <digitalRead+0x82>
#endif
#if defined(TCCR2A) && defined(COM2A1)
case  TIMER2A:  cbi(TCCR2A, COM2A1);    break;
    13b2: 80 91 b0 00 lds r24, 0x00B0
    13b6: 8f 77        andi r24, 0x7F ; 127
    13b8: 03 c0        rjmp .+6      ; 0x13c0 <digitalRead+0x7e>
#endif
#if defined(TCCR2A) && defined(COM2B1)
case  TIMER2B:  cbi(TCCR2A, COM2B1);    break;
    13ba: 80 91 b0 00 lds r24, 0x00B0
    13be: 8f 7d        andi r24, 0xDF ; 223
    13c0: 80 93 b0 00 sts 0x00B0, r24
if (*portInputRegister(port) & bit) return HIGH;
    13c4: 89 2f        mov r24, r25
    13c6: 90 e0        ldi r25, 0x00 ; 0
    13c8: 88 0f        add r24, r24
    13ca: 99 1f        adc r25, r25
    13cc: 84 58        subi r24, 0x84 ; 132
    13ce: 9f 4f        sbci r25, 0xFF ; 255
    13d0: fc 01        movw r30, r24
    13d2: a5 91        lpm r26, Z+
    13d4: b4 91        lpm r27, Z+
    13d6: 8c 91        ld r24, X
    13d8: 20 e0        ldi r18, 0x00 ; 0
    13da: 30 e0        ldi r19, 0x00 ; 0
    13dc: 84 23        and r24, r20
    13de: 11 f0        breq .+4      ; 0x13e4 <digitalRead+0xa2>
    13e0: 21 e0        ldi r18, 0x01 ; 1
    13e2: 30 e0        ldi r19, 0x00 ; 0
return LOW;
    13e4: c9 01        movw r24, r18
    13e6: 08 95        ret
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
jahronchek
#10
Jul 28, 2012, 06:35 am Last Edit: Jul 28, 2012, 06:53 am by Checkers1811 Reason: 1
It looks to me like objdump will do what I need.
Thanks
I really would like to be able to run the compiler manually on a file or two, so thanks for the compiler switches.
Not interested in running a makefile on Windows, excepting for the experience gained.
So, where do I find objdumP? A leading question indeed as there are many copies on my PC. Why so many? Who knows?
There is C:\WinAvr-20100110, C:\WinAVR-20090313, C:\Program Files (x86)\Atmel\AVR Tools\AVR Toolchain\bin; and then there is the one inside of the Arduino installation down in E:\Arduino Projects\Arduino\arduino-0021\arduino-0021\hardware\tools\avr.
DuaneB
   I use the one from the Arduino install with the -s switch and run it against the cpp.elf file, here is a sample of my command line -
Code: [Select]
C:\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\obj-dump -s C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build5704327072959987835.tmp\RCChannelsL293D.cpp.elf > RCChannels.txt
Duane B
Read this
then watch this
optimistx
When using Arduino IDE 1.0.5 I do not get the nice assembler listing with intermingled C-code (or C++ code) of the sketch.  I experimented with this:
avr-objdump -S -l -C -h -t  myprogram.cpp.elf > mylisting.txt
There are line numbers of my original sketch but no the contents of the line.
Of course, by putting the original sketch and the listing.txt side by side one can find the correnspondence. Is there a simple trick to correct this?
(I put on the verbose listing to find the file location of the *.elf).
My commands for the blink.ino was:
Code: [Select]
"C:\Program Files\Arduino\hardware\tools\avr\bin\avr-objdump" -S -l -C -h -t  C:\DOCUME~1\ANANAB~1\LOCALS~1\Temp\build4286924063808951866.tmp\Blink.cpp.elf > Blink.txt
and part of the output file Blink.txt, covering the loop() of the blink.ino:
Code: [Select]
00000100 <loop>:
loop():
C:\Program Files\Arduino/Blink.ino:20
100: 80 91 00 01 lds r24, 0x0100
104: 61 e0        ldi r22, 0x01 ; 1
106: 0e 94 b8 01 call 0x370 ; 0x370 <digitalWrite>
C:\Program Files\Arduino/Blink.ino:21
10a: 68 ee        ldi r22, 0xE8 ; 232
10c: 73 e0        ldi r23, 0x03 ; 3
10e: 80 e0        ldi r24, 0x00 ; 0
110: 90 e0        ldi r25, 0x00 ; 0
112: 0e 94 e5 00 call 0x1ca ; 0x1ca <delay>
C:\Program Files\Arduino/Blink.ino:22
116: 80 91 00 01 lds r24, 0x0100
11a: 60 e0        ldi r22, 0x00 ; 0
11c: 0e 94 b8 01 call 0x370 ; 0x370 <digitalWrite>
C:\Program Files\Arduino/Blink.ino:23
120: 68 ee        ldi r22, 0xE8 ; 232
122: 73 e0        ldi r23, 0x03 ; 3
124: 80 e0        ldi r24, 0x00 ; 0
126: 90 e0        ldi r25, 0x00 ; 0
128: 0e 94 e5 00 call 0x1ca ; 0x1ca <delay>
C:\Program Files\Arduino/Blink.ino:24
12c: 08 95        ret
The  Blink.ino :
Code: [Select]
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
westfw
Add "-I yourSketchDir" to the obj dump cmd.
optimistx
#14
Sep 17, 2013, 02:31 pm Last Edit: Sep 18, 2013, 01:51 pm by optimistx Reason: 1
Thanks, that improved the situation somewhat. There is a keyword from the source line in the assembler list, but not everything, e.g. arguments of the functions are not there.  Now loop() and setup() from the Blink.ino look like this:
Code: [Select]
00000100 <loop>:
loop():
12c: 08 95       ret
0000012e <setup>:
setup():
C:\Program Files\Arduino/Blink.ino:15
12e: 80 91 00 01 lds r24, 0x0100
132: 61 e0       ldi r22, 0x01 ; 1
134: 0e 94 79 01 call 0x2f2 ; 0x2f2 <pinMode>
C:\Program Files\Arduino/Blink.ino:16
138: 08 95       ret
Is  this the expected result or can it still be improved?
Edit. (blushing...). No, the assembler lists are the same! Something done wrong?
Arduino library routines are listed well, but the main sketch is not. E.g. the delay() is nice:
Code: [Select]
void delay(unsigned long ms)
uint16_t start = (uint16_t)micros();
while (ms > 0) {
270: 21 15       cp r18, r1
272: 31 05       cpc r19, r1
274: 41 05       cpc r20, r1
276: 51 05       cpc r21, r1
278: 71 f6       brne .-100     ; 0x216 <delay+0x4c>
C:\Program Files\Arduino\hardware\arduino\cores\arduino/wiring.c:119
if (((uint16_t)micros() - start) >= 1000) {
ms--;
start += 1000;
27a: 08 95       ret
Perhaps the main sketch should be modified to look like a library?
Edit: Now it worked with the -I -switch. :)  . I do not know what was wrong earlier. The info at
http://forum.arduino.cc/index.php?topic=160587.5;wap2
made me work harder and there was success. Thanks westfw!
