Topic: Arduino UNO and inspeed vortex wind speed sensor. (Read 5341 times) previous topic - next topic
panagath
Hello all, I'm new in arduino developing. I want to use this sensor "http://www.inspeed.com/anemometers/Vortex_Wind_Sensor.asp" . It is supposed to create pulses and I have to measure the frequency in order to get my data.  Can someone please advice how can I do it with arduino UNO? What libraries can I use? I guess I will use the interupts , right? What else do I need to get readings from the sensor? Thanks in advance.
pylon
Just put one wire to GND, the other to pin 2 (external interrupt 0) with a pullup resistor (10k should be OK) to 5V.
Then use the example code from attachInterrupt() (http://arduino.cc/it/Reference/AttachInterrupt). You have to register the time difference between two pulses (use micros() for that) and calculate the frequency from that.
Heimdallofasgard
Hi Pylon,
Just wondering what you meant by a pull up resistor?
Thanks
- Heim
pylon
iandeboisblanc
I'm having trouble actually pulling the windspeed from the anemometer. It seems that the hall-effect sensor will send multiple pulses for each rotation if the windspeed is low enough. To account for this, I tried to set a required time differential between pulses, but when I set an adequate threshold (~0.1s) I lose performance at higher windspeeds (i.e. 25mph at 10Hz). Anyone have any suggestions?
pylon
I would have to see how the signal looks like in low and high speed situations.
My first try would probably be to depend the time difference on the last value I calculated. That's because the wind speed cannot change immediately but it needs some time to accelerate the anemometer.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
