Topic: How do I control fan speed on 12V DC fan? (Read 61365 times) previous topic - next topic
Grumpy_Mike
Is that the only code you are running? If so there is nothing that turns on the fan. It just sets the brightness of an LED to the value on the pot. If you still have your fan wired up as above it is connected to pin 7 which the code is not touching. If you move the base from pin 7 to pin 11 the fan should come on.
PS. When posting code here copy it, then hit the hash icon on the top row of the reply box (9 from the left) and paste the code between the two sets of square brackets that pop up. In that way you have a scrollable window and it saves space.
Chronicdiving
Thank you mike for the tip
int fanA= 4;
int fanB = 7;
int fanC= 8;
int fanaVal = 0;
int fanbVal = 0;
int fancVal = 0;
int potpinA = 0;
int potpinB = 1;
int potpinC = 2;
char controlChar;
void setup() {}
fanaVal = analogRead(potpinA);
fanbVal = analogRead(potpinB);
fancVal = analogRead(potpinC);
analogWrite(fanA, fanaVal);
analogWrite(fanB, fanbVal);
analogWrite(fanC,fancVal);
So the above code gets it to respond to the potentiometer but it seems that there is no real noticeable change in the speed and when i check the power range the fan is receiving it just jumps from 0V to 11.47V when i turn the 10K pot...any thoughts as to why i'm still not getting any feasible range of voltages?
Would it be possible to apply power to the fan and then let it coast to a certain rpm then apply power again kind of to perpetuate a slower rotation, is that possible?
thanks!!
anachrocomputer
Remember that analogRead() returns 0-1023 and analogWrite() needs 0-255.  You'll need to do some scaling!
Chronicdiving
Very true(i'm mostly familiar with 255 in DMX lighting control) but shouldn't i get more than a 0.27 voltage change on a 10K pot?
Is Arduino written in C or JAVA?
Chronicdiving
Come to think of it i'm not sure it matters what it's written in since AP JAVA was a year ago and C++ is this coming semester so i'm stuck in the no man's land of forgot more than i learned and won't brush up until class starts   :-p
anachrocomputer
Well, that depends on how the pot is wired up.  Can you show us a schematic?
Chronicdiving
Chronicdiving
#37
Jan 07, 2009, 09:45 pm Last Edit: Jan 07, 2009, 10:13 pm by Chronicdiving Reason: 1
There ya go!
nigel_mck
The analogWrite functions only work with pins marked with PWM! You need to change the motor pins to ones marked with PWM.
That should solve your problem!
Nigel
anachrocomputer
with the pot wired like that (which is correct), you should get a voltage range of zero to 5V on your analog input pin.  You can, of course, check that with a multimeter.
But, do you need any pinMode() calls in your 'setup()' function?  Do you need to select analog input mode on potPinA, potpinB, potpinC?  And do you need to specify PWM output on the other pins?  I'm not sure, myself, but I have seen that sort of thing in other Sketch code.
Chronicdiving
Great! I changed the code to the one below and it's working great...only down side is this 10K doesn't seem to be very coarse so i'll get 100K or maybe 1M that way it will be easier to change...i've got a 2-11.47V range so there's enough variation that i was seeing different patterns which is really cool...thanks Nigel for the correction!
int fanA= 3;
int fanB = 5;
int fanC= 6;
int fanaVal = 0;
int fanbVal = 0;
int fancVal = 0;
int potpinA = 0;
int potpinB = 1;
int potpinC = 2;
char controlChar;
void setup() {}
anachrocomputer
#41
Jan 08, 2009, 01:41 am Last Edit: Jan 08, 2009, 01:42 am by anachrocomputer Reason: 1
The value of the pot won't affect the "coarseness" or "fineness" of the control.  And 10k is as large a value as will work properly with the Arduino (due to the ADC input capacitance).  Could you compensate for the difficulty in control by scaling or offsetting the numbers in the code?
Oh, and that code still has no pinMode() calls nor scaling -- are you sure it's the right version?
Chronicdiving
Anachrocomputer, thanks!, lol i have no idea to 1/2 those questions but the current code seems to be working just fine
Grumpy_mike...i was sleuthing around and i found your website...great stuff! tutorials are also good...what magazine did you used to write for again?
So here's the code I have for my past LED project
int bluePin = 9;
int redPin = 10;
int greenPin = 11;
// readings from the serial port
int blueVal = 0;
int redVal = 0;
int greenVal = 0;
char controlChar;
 analogWrite(redPin, redVal);
 analogWrite(greenPin, greenVal);
 analogWrite(bluePin, blueVal);
 if (Serial.available() >= 2) {
   controlChar = Serial.read();
   if (controlChar == 'r') {
     redVal = Serial.read();
   } else if (controlChar == 'g') {
     greenVal = Serial.read();
   } else if (controlChar == 'b') {
     blueVal = Serial.read();
This takes info from a program that reads the internal mic on the computer to create a "beat to music" effect
How could I get the fan sketch that's uploaded to the board to interpret the data from the LED program?
Thanks!
Chronicdiving
#43
Jan 08, 2009, 01:50 am Last Edit: Jan 08, 2009, 01:52 am by Chronicdiving Reason: 1
anachrocomputer...so 10K pot is the highest the arduino can read? I guess scaling would work, so you would have to basically write it so that it was a 10:1 ratio with the pot taking 10x as many degrees to change 1 volts worth, yeah?
I'm pretty positive that's the right code...although i haven't done any scaling yet(i'm not strong enough in coding to really put any of this stuff together myself yet although hopefully after this semester is over i should be able to)
Here's what's on the board right now and when i turn the pot the fans slow down and speed up...i put a multimeter on the + and - of the fan and i got 3-11.47V
int fanA= 3;
int fanB = 5;
int fanC= 6;
int fanaVal = 0;
int fanbVal = 0;
int fancVal = 0;
int potpinA = 0;
int potpinB = 1;
int potpinC = 2;
char controlChar;
void setup() {}
anachrocomputer
#44
Jan 08, 2009, 01:57 am Last Edit: Jan 08, 2009, 01:57 am by anachrocomputer Reason: 1
Higher value pots than 10k will work, but there is a (theoretical) small error due to input capacitance at the AVR's pin.  And anyway, the value of the pot won't affect the voltage when it's wired up as you have is, as a voltage divider.  When the pot's wiper is half-way along the track, the voltage will be 2.5V at the analog pin, regardless of the value of the pot.
Wait a minute, that's made me think of something!  Is your pot a "log" or "lin" pot?  Logarithmic or linear, that is?  Log pots are sometimes called "audio taper" in the USA, I think.  You need a linear pot for this sort of application.  Check the voltage at the pot's centre terminal as you turn it, and see if half-way corresponds to 2.5V.
