thanks for the help, if remove the servo for my circuit and run the code complete (nothing commented out), the LCD is still unreadable, so the issue isn't servo or current related
any ideas
Hmmm, that reminds me, the Servo library has this warning:
The Servo library supports up to 12 motors on most Arduino boards and 48 on the Arduino Mega. On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10, whether or not there is a Servo on those pins. On the Mega, up to 12 servos can be used without interfering with PWM functionality; use of 12 to 23 motors will disable PWM on pins 11 and 12. The tutorial for LiquidCrystal says you should hook up the lcd to pin 9 with PWM. So you might need to rearrange the wiring to move the LiquidCrystal PWM to another PWM pin (3, 5, 6,or 11), but you may then have to move wires on other pins, to get to to one of the PWM pins.
