Topic: brushless motors ,esc , quadcopters (Read 4828 times) previous topic - next topic
deepu1994
Jul 29, 2012, 02:45 pm Last Edit: Jul 29, 2012, 03:39 pm by deepu1994 Reason: 1
hi,,, sorry for creating this seperate but this would be much more usefull to all my friends who are part of the arduino team...to get this info quickly...
here is my problem......
how can i check my brushless motor belonging to topstar 2400kv http://topbandmotor.en.alibaba.com/product/427426170-212087816/brushless_dc_motor.html,, and esc belonging ipeaka 40A and 45A burst for 10shttp://www.ecvv.com/product/3694372.html,,,and with my arduino uno rev3????
when i use the following code
Code: [Select]
#include <Servo.h>    // including the servo library
Servo motorServo;     // naming the servo as "motorServo"
{              // runs code once on setup:
 motorServo.attach(9);   // reporting the pin motorServo is attached to
 throttle();
{              // runs code repeatedly:
 setRpm(40);
void throttle()
 motorServo.write(0);   // sets the throttle to 0
 delay(1000);           // waits one second
void setRpm(int spd)
 int rpm = map(spd, 0, 100, 0, 179);    // maps rpm to a motor-friendly number
 motorServo.write(rpm);                     // sets motor to the rpm speed
 delay(15);                                        // waits for motor to get there
this does not work practically but as per theory its right (verify was successful)>>>> :( :|
MarkT
Every ESC has its own arming sequence and will refuse to start up if you don't follow it - this prevents injury when tinkering with an RC plane.
Generally many ESCs will arm if the throttle is set to zero for several seconds at start up (1 second is definitely rather short) and then _ramped up_ to speed.  Sudden step changes could be break-through from another RC channel and treated as an error condition perhaps?   If you have an RC transmitter and receiver you can experiment with it to see what your ESC likes.
This sequence is more conservative and I think might have a better chance of working.  Most ESCs chirp the motor to indicate status, typically 3 beeps upon arming
Code: [Select]
  setRpm (0) ;
  delay (4000) ;
  for (i = 0 ; i <= 40 ; i++)
    setRpm (i) ;
    delay (20) ;
The actual throttle settings for you particular ESC you'll have to experiment with.  I definitely use the higher-resolution calls to servo.write() where you pass the pulse-width in microseconds (540 to 2400 is the valid range).
deepu1994
i cant get u >>>> becoz.....according to the manual of my ipeaka esc 40A...it needs a min throttle signal to arm itself>>>> then a continuous three beep sound when armed... the if we increase the throttle signal the motor accelerates up......
in my case it arms well but when i supposed to increase the throttle it keeps in beeping continuously........
MarkT
deepu1994
hi tnx for u r help anyway>>> i came out of that easily with my prof advise>>>
he advised me to use the microseconds value for the esc and arm the same >>>
my esc arms at 100ms and has the highest throttle range of 2000ms......
now all is working like charm>>>>\
my next point of interest is using the gsm module and the at commands>>>>
kindly give me essential details
Code: [Select]
#include <Servo.h>
Servo motor;
void esc() {
  delay(5000);
  Serial.print("Sending lowest throttle");
  motor.writeMicroseconds(1000);
  delay(2000);
  Serial.print("Low throttle sent");
  motor.attach(9);
  Serial.print("ESC calibration started");
  esc();
  Serial.print("ESC calibration completed");
  if (Serial.available()>0) {
    int key = Serial.read();
    switch(key) {
      case '1':
      motor.writeMicroseconds(1250);
      delay(2000);
      case '2':
      motor.writeMicroseconds(1400);
      delay(2000);
      case '3':
      motor.writeMicroseconds(1750);
      delay(2000);
      case '4':
      motor.writeMicroseconds(2000);
      delay(2000);
      case '5':
      motor.writeMicroseconds(2500);
      delay(2000);
      default:
Tjhis is the code i used for controlling the motor
KUCKY
Hello together,
I think I'm right here. With a very similar code, I run my BL. But I have difficulties to control 4 BL's. Can you help me please.
Regards
Kucky
MarkT
Some more information - "have difficulties" isn't very informative...
KUCKY
Sorry, diese info war wirklich zu kurz.
Here my code:
Code: [Select]
#include <Arduino.h>
#include <Servo.h>
Servo rotor_1;
Servo rotor_2;
Servo rotor_3;
Servo rotor_4;
#define PINESC1 2
#define PINESC2 3
#define PINESC3 4
#define PINESC4 5
  int rotorMillis1 = 0;
  int rotorMillis2 = 0;
  int rotorMillis3 = 0;
  int rotorMillis4 = 0;
  int speed1 = 0;
  int speed2 = 0;
  int speed3 = 0;
  int speed4 = 0;
Serial.println("****************************");
Serial.println("*    Rotoren Test          *");
Serial.println("* Parameter = Microseconds *");
Serial.print  ("*  ");Serial.print(__DATE__);Serial.print(" ");Serial.print(__TIME__);Serial.println("    *");
rotor_1.attach(PINESC1);
rotor_2.attach(PINESC2);
rotor_3.attach(PINESC3);
rotor_4.attach(PINESC4);
arm();
ReadKeybord();
rotor_1.writeMicroseconds(rotorMillis1);
rotor_2.writeMicroseconds(rotorMillis1);
rotor_3.writeMicroseconds(rotorMillis1);
rotor_4.writeMicroseconds(rotorMillis1);
void ReadKeybord()
int key = 0;
if(Serial.available() > 0)
switch(key)
case '8': /// beschleunigen
rotorMillis1 = mapPWMtoMS(speed1 += 1);
Serial.print("Beschleunigen - ");Serial.println(rotorMillis1);
case '2': /// abbremsen
rotorMillis1 = mapPWMtoMS(speed1 -= 1);
Serial.print("Abbremsen - ");Serial.println(rotorMillis1);
case '5':
speed1 = 0;
rotorMillis1 =  mapPWMtoMS(speed1);
Serial.print("Stop - ");Serial.println(rotorMillis1);
Serial.flush();
int mapPWMtoMS(int speed)
int _MS = 0;
_MS = map(speed, 0, 100, 1000, 2000);
return(_MS);
void arm()
Serial.println("Arming begins.");
delay(6000); ///?????
Serial.println("Now writing maximum output.");
        Serial.println("Wait 2 seconds.");
Serial.println("Arming ESC 1");
        rotor_1.writeMicroseconds(2000);
delay(2000);
rotor_1.writeMicroseconds(1000);
delay(100);
Serial.println("Arming ESC 2");
rotor_2.writeMicroseconds(2000);
delay(2000);
rotor_2.writeMicroseconds(1000);
delay(100);
Serial.println("Arming ESC 3");
        rotor_3.writeMicroseconds(2000);
delay(2000);
rotor_3.writeMicroseconds(1000);
delay(100);
Serial.println("Arming ESC 4");
rotor_4.writeMicroseconds(2000);
delay(2000);
rotor_4.writeMicroseconds(1000);
delay(100);
Serial.println("Armig is finished");
Not always run all the motors.
Sometimes only 1,2 and 3.
Sometimes only 1,3 und 4 or others.
I suspect it's the arm of the ESC's.
Can you help me.
Best Regards
Kucky
MarkT
Why not arm them all at the same time - perhaps they will time-out if not armed soon after power-up?
Chagrin
Code: [Select]
void arm()
delay(2000); // might want to add more delay
delay(100);
Serial.println("Arming has finished");
KUCKY
Thanks for the code. Now it works, strange. But I have the ESC's 2 times on and off and then reset the Arduino.
Willi
