Topic: Where can I purchase a 120ac in isolated transformer? (Read 2246 times) previous topic - next topic
d0773d
I have been searching google to purchase a 120v ac isolated transformer to stepdown the ac voltage to something usable.  Does anyone have a link to a website?  I plan I building my own benchtop ac/dc transformer.  I realize I can buy a manufactured one, but I want this to be a learning experience.  Thanks!
Grumpy_Mike
Hard to say because you haven't filled in your location.
Not sure what you mean. They are all manufactured unless you wind your own coil.
d0773d
I'll have to fix that, but for now I live in Arizona.   I meant I would like to build my own benchtop AC to DC converter.  I would like to buy a isolated AC transformer and all the electronic components needed to build the AC to DC converter.  I can find all the components except the ac transformer.
CoolJ
If you don't need a large and expensive one you will probably have to make it your self. You can use two suitably sized step down transformers wired low to low and you would have created an isolated, current limited,  ~120v source.
You have also not communicated the intended scope of your project properly.
Power requirements?
Why would you strictly need a 120v-120v Isolated transformer?
If indeed that is what you need. It's hard to tell from what you have presented.
By design, transformers are isolated. They are electromagnetically coupled.
So I guess I am not really sure what you are asking for.
doughboy
what exactly is your learning objective?
I did a benchtop power supply project like 30 years ago and I can't imagine that will have the same learning value nowadays.
d0773d
The learning objective is just that, "learning." The final outcome of this project
is to have a functioning benchtop variable AC to DC transformer from 1volts to maybe 24volts. I know I can purchase one on Amazon for a relatively low price, but I want to build one to learn the theory and the functionality.
d0773d
Scratch that last suggestion, I meant circuit specialists and I see they're over in Mesa, now.
(Too early, need coffee.)
I checked out their website and they seem promising. Do you happen to know of any other websites besides digikey or mouser?
doughboy
no objections to the learning part. just merely suggesting that there might be more beneficial areas to spend your resource on (perhaps build a switching power supply?). as it is like learning vacuum tubes circuit. its a bit outdated.
winner10920
You can make a 2.5 to 40v supply with just a lm317, well not much supply mostly a reference at any more than 20v any current draw would be ridiculous
Gotta agree if you made an adjustable switching supply it would be usefull, effecient and plenty experience
winner10920
P.s while your at it why not a dual adjustable supply?
Grumpy_Mike
Docedison
Here are some drawings for a Power Supply... Good Luck in the contest.
--> WA7EMS <--
justjed
Not at all. There are many things to learn in this process. Filtering, for one. Or, if the OP decides to go the switching route, there's oscillators. And tubes still have their place too.
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
