Loading...
Pages: [1] 2   Go Down
Author Topic: HELP ME WITH DESIGN Eagle file - my first proyect  (Read 2581 times)
Offline Offline
Newbie
View Profile
Hello
     I made my first prototype, is a simple project that I want to accomplish. I have finished the prototype, it is an Arduino uno + ethernet shield with a motion sensor, and the function is detect movement and send a notification for internet.
      I want to create a PCB with the included motion sensor and only with elements I used in the prototype. for example only the PINS i use (PIN: 2, GND, 5v) etc. is for reduce the size and make a small device.
      Someone can help me design the EAGLE FILE? promissory for it.
thanks
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Are you keeping the ethernet shield? Or just wiring your combined minimal component/PIR board to it?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
yes i have the ethernet shield connected to the arduino uno and the PIR sensor connected too.
   i want make a board using only the PINs that i use. The microcontroler, the PIR SENSOR and ETH SHIELD for reach a small device
Regards
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Well, I think I would start with the eagle file for the ethernet card and add components to that.
Add the ATMega328 only requires a few components - uC, xtal, 2x 22pf caps, 4x 100nF caps, 10k resistor, small diode.
ICSP header pins for downloading bootloader if needed, USB/Serial header pins for down loading sketches, or adding USB connectivity out to a PC while debugging.
Don't know what PIR you have, I don't they use very many components.
How are you powering? Do you need a 3.3V or 5V regulator? Or will you bring one or both in directly?
Logged
Offline Offline
Newbie
View Profile
ok, let me try... is the first time i use eagle.. for this reason ask for some disingner....
i use the this PIR http://www.ebay.es/itm/170842963267?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1635wt_1180
and the power for the moment is the USB power but i want add POE or a rechargable solar batery.... i need  study this part.
Regards
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Okay, with that PIR you may as well make room on your board to attach the PIR board, or just use connector pins to plug the PIR cable onto.
Logged
Offline Offline
Newbie
View Profile
Thanks... i will try to desing the schematic..
Logged
Offline Offline
Newbie
View Profile
I'm trying to make the schematic with eagle but i am lost.. i dont know the element the i need for create the board...
    I did the prototype in FRITZING is to simple... i acept improvements  smiley-wink
    ahhh remenber that the infrared sensor is not a realy infrared... is a PIR SENSOR is just that in Fritzing is not the PIR sensor
    i attach too the schematic that Fritzing generate...
    I want make the schematic correctly... with only the things that i use...... I am grateful if someone can help me do it.
Big Thanks!!
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Eagle files for the boards are listed with those boards on the hardware page of this site. Assuming your plan is to design a custom Arduino with ethernet and PIR then you can start from the Uno and start adding/moving/removing components.
Logged
Offline Offline
Newbie
View Profile
yes, that is what i want.... i thinks is better the arduino ethernet and modify/remove or add the components that i need. but that is my problem.... here i am lost.. i dont know  whats remove or how add. smiley-sad
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Add the ATMega328; only requires a few components - uC, xtal, 2x 22pf caps, 4x 100nF caps, 10k resistor, small diode.
Basically the parts that make up a Promini with the 2 sets of header pins for programming.
Logged
Offline Offline
Newbie
View Profile
I am trying to desing the schematic... I will tell you something
Thanks you very much
Logged
Offline Offline
Newbie
View Profile
i have the following schematic.
I modified the arduino ethernet removing all components unnecessaries. only need to add the PIR sensor.
is good way to to get what I want?
Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
Take a look at this, it is what you need minus the PIR. https://www.sparkfun.com/products/11229
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Looking at the Arduino ethernet schematic, I'm thinking yes.
http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Dev/Arduino/Boards/arduino-ethernet-schematic.pdf
Logged
Pages: [1] 2   Go Up
Print
Jump to:
