It was recommended I shorten my spiel, so let me summarize my problem.
I have an UNO setup running code to turn a few relays on and off. It's a timer mechanism for this larger machine.
THE PROBLEM:
I had all of this running, originally. It was great. Every 2 hours or so, I would have an issue with the LCD characters going "nonsense" but the addition of 10nF caps on the LCD power helped limit the problem.
Trouble is, I had to modify the system for larger relays. I didn't change anything, *honestly.* I just put in some new relay boards with slightly higher current ratings.
Now, I have this new lcd "nonsense" issue. I get what looks roughly like the characters i'm supposed to be getting, but a few artifacts and this persistent "scrolling" issue. You can see in my code I never use the scrolling function of the library. I'll try to add pictures soon.
I'm running one of the standard Microtivity 16x2 LCDs. I bought it off Amazon. I don't think it's the source of the problems,
I have:
Tried a second LCD. Same exact problem.
Inspected all the wiring for frays or PCB problems. nothing.
Still Considering:
Rewiring everything??
Switching out my Atmega328??
NO IDEA:(
I will:
Upload a picture, soon. See uploaded pictures, below.
MY CODE IN SUMMARY:
#include <LiquidCrystal.h>
long StartTime;
int debounce = 1200;
int reading;
int previous;
int bounceTime;
int state;
LiquidCrystal lcd(7, 8, 9, 10, 11,12);
pinMode(BeginSwitch,INPUT);
lcd.begin(16, 2);
delay(50);
lcd.print("Hello,*****!");
delay(750);
void loop(){
//BEGINING POTIOMETER TIMING SECTION
digitalWrite(PressPower,HIGH);
digitalWrite(PressPower2,HIGH);
digitalWrite(FanPower,LOW);
digitalWrite(PressLight,LOW);
// Next, Convert the analog readings (which go from 0 - 1023) to a time (0- 180) minutes:
state = HIGH;
digitalWrite(BeginSwitch,HIGH); //This sets a pull-up resistor on begin switch.
do{
int Potvalue2 =(analogRead(Pot2));
Time= (Potvalue2*(180/1023.0));
lcd.clear();
lcd.print("Inputing Timer");
lcd.setCursor(2,2);
lcd.print(Time,DEC);
lcd.setCursor(6,2);
lcd.print("minutes");
delay(200);
reading = digitalRead(BeginSwitch);
if (reading != previous) {
// reset the debouncing timer
bounceTime = millis();
if ((millis() - bounceTime) > debounce) {
state = reading;
previous = reading;
}while(state==HIGH);
//End BeginSwitchState section statement
delay(250); //Trying to avoid the bounce of the switch.
lcd.clear();
lcd.print("Switch to Power");
StartTime=millis();
MY CODE IN FULL:
[size=6pt]#include <LiquidCrystal.h>
const int PressPower = 18; //
const int PressPower2 =19; //A0 = pin 14, A1=15,A2=16,A3=17,A4=18,A5=19
const int Pot2 = A2; //Pot2 is actually the only pot. (Originally there was a course and fine adjust, but the fine was enough.)
const int BeginSwitch = 3;
/* Begin switch will be a switch "Open" if timing is to be measured,
"closed" if timing is finished measuring". I.E, I'm pulling it from 5v to 0v
when the switch is pressed. This is so I can use the internal pull-up*/
//NOTE: IF TROUBLE UPLOADING: Disconnect pins 0 and 1 during the upload. They can interfere sometimes.
long Time;
long FanDuration;
long FanCountDown;
long FanTime;
long StartTime;
long PressEndTime;
int reading;
int previous;
int bounceTime;
int state;
const int PressLight =13;
const int FanPower = 2; //We avoid Pihn 13, for now, because of built in LED
pinMode(PressPower,OUTPUT);
pinMode(PressPower2,OUTPUT);
pinMode(FanPower,OUTPUT);
pinMode(PressLight,OUTPUT);
pinMode(Pot2,INPUT);
lcd.begin(16, 2);
delay(50);
delay(750);
void loop(){
state = HIGH;
do{
lcd.clear();
lcd.setCursor(2,2);
lcd.setCursor(6,2);
delay(200);
state = reading;
previous = reading;
lcd.clear();
StartTime=millis();
do
digitalWrite(PressPower,LOW); //YOU CAN USE A PULL DOWN RESISTOR TO TRY AND FORCE IT AS GROUND. I.E, resistor to grn.
digitalWrite(PressPower2,LOW);
digitalWrite(PressLight,HIGH);
lcd.clear();
long CountDownSeconds = (millis()-StartTime)/1000;
long CountDown=Time-(CountDownSeconds/60);
lcd.print("ON, Countdowns");
lcd.setCursor(1,2);
lcd.print(CountDown,DEC);
lcd.setCursor(3,2);
lcd.print("mins=");
lcd.setCursor(8,2);
long Seconds=(Time*60)-CountDownSeconds;
lcd.print(Seconds,DEC);
lcd.setCursor(13,2);
lcd.print("Sec");
PressEndTime=millis();
}while((millis()-StartTime) < (Time*60*1000));
do {
digitalWrite(FanPower,HIGH);
lcd.clear();
lcd.print("Fan Time!");
lcd.setCursor(2,2);
FanCountDown=(millis()-PressEndTime)/1000; //"FanCountDown" is actually a count UP.
long Timer=(90*60)-FanCountDown; //FAN COUNTDOWN IN SECONDS
lcd.print(Timer,DEC);
}while(FanCountDown<(90*60));
//END OF FAN POWER SEQUENCE
for(long t=1;t<8667;t++) {
//This should give a 3 day delay before the circuit resets to input (even though the switch is on "GO!", the debounce should be stuck in reading = previous)
//I believe I could just remove the void loop but I decided not to. Will research sleep mode later.
lcd.clear();
lcd.print("Done,******!");
lcd.setCursor(0,2);
lcd.print("(Turn Off Timer)");
delay(150000);
}//END OF PROGRAM // Personal Note, you might not need the void loop, since this only runs once
[/size]
