Pages: 1 2 [3]   Go Down
Author Topic: Pitolino - a small data logging gadget  (Read 1920 times)
Rapa Nui
Pukao hats cleaning services
Thanks, maybe I will follow the idea "it does not matter" with the numbering scheme, as I do not see any need to follow the ..duino shield numbering. Frankly - D31 tells me nothing, but PD7 means bit number 7 on port D  smiley-razz  smiley-razz
So currently I will stay with the numbering as is.. avr-developers (..maniac-bug uses clockwise PA numbering).
p.
I don't think the labels on the board matter too much, Teensy is easy to use with port-bit labels.
Pin Numbers are a pain but they permeate Arduino software so you do need a mapping.  It would be nice if you didn't add another variant.
Are you using the mapping with D31 = A7 = PA0 or the one with D31 = A7 = PA7?
It would be helpful if the variants for 1284P had names.  You can't build fast I/O libraries using pins_arduino.h.  You need to use some compile time trick so digital read and write compile to cbi/sbi instructions.
Paul Stoffregen defined the symbol CORE_TEENSY.  This permits the Teensy to be distinguished from the Leonardo.  This define allows add both Teensy and Leonardo to be added to libraries for fast digital I/O and software SPI.
Currently I use the Sanguino mapping for 644/1284 in my fast I/O libraries.  It had PA0 = D31 but D31 was analog pin 0.
« Last Edit: August 04, 2012, 10:43:55 am by fat16lib » Logged
Where are these fast i/o libraries for Sanguino?
Rapa Nui
@fat16lib: a good point. I used sanguino pin def in past. Now I am migrating to 1.0.1. I am using mega32 and 1284p. I downloaded maniac-bug hw variants, and created a variant based on his avr-developer variant for my atmega32. I did not elaborate 1284p with 1.0.1.
Running mylogger on atmega32 under 1.0.1 (includes lcd4x20, sdfat, bmp085, i2c, rtc8563, servo, time) I do not have any issue yet.
So for pitolino I see 2 variants applicable (see attached):
maniacbug-mighty-1284p/ standard
static const uint8_t A0 = 24;
static const uint8_t A1 = 25;
static const uint8_t A2 = 26;
static const uint8_t A3 = 27;
static const uint8_t A4 = 28;
static const uint8_t A5 = 29;
static const uint8_t A6 = 30;
static const uint8_t A7 = 31;
   _BV(0), /* 24, port A */
   _BV(1),
   _BV(2),
   _BV(3),
   _BV(4),
   _BV(5),
   _BV(6),
   _BV(7)
maniacbug-mighty-1284p/ avr-developers
   _BV(7), /* 24, port A */
   _BV(6),
   _BV(5),
   _BV(4),
   _BV(3),
   _BV(2),
   _BV(1),
   _BV(0)
Not sure the definitions are correct (see the below pictures)
Now which one is better??
« Last Edit: August 04, 2012, 01:58:49 pm by pito » Logged
Peoples Republic of Cantabrigia
Arduino happiness
Pito, FWIW, your order of pins as written is the same even though the schematic suggests the opposite (i.e. A0 = A7)
Rapa Nui
Which schematics? There are three of them: mine on the PCB (A0=D31), standard (A7=D31) and avr-developers Sanguino (A0=D31)..
The order of pins in avr-developers maps mines, but the definitions (ie static const uint8_t A0 = 24;) does not, therefore I think there is an issue with those defs..
« Last Edit: August 05, 2012, 02:35:30 am by pito » Logged
florinc,
I just posted a new version of the fast I/O libraries as DigitalPinBeta20120804.zip  http://code.google.com/p/beta-lib/downloads/list.
Standard 168/328, Mega, Teensy, Leonardo, Teensy++, and Sanguino are supported.
Thanks fat16lib.
Rapa Nui
Added schematics v 0.2.
p.
Arduino happiness
Sorry about that,misread the data you posted.
Boston area, metrowest
Why not bring the RTCs ClockOut (pin 7, labeled as Vback on the sysmbol) to a 1284 pin also?
Can use it as 1 Hz interrupt source (or 32 Hz, 1 KHz, 32 KHz).
Rapa Nui
RTCs pin7 CLKOUT - open collector (or hiZ when disabled) - frequencies of 32.768 kHz (default), 1.024 kHz, 32 Hz, and 1 Hz. Yes, that could be possible - I would suggest connect it to PC4 (via 220ohm jumper resistor and 33k pull-up).
UPD sch v0.3
« Last Edit: August 06, 2012, 04:39:10 pm by pito » Logged
Pages: 1 2 [3]   Go Up
