Topic: KVM to Ethernet with arduino.. is it possible? (Read 9090 times) previous topic - next topic
vputz
#15
Jan 13, 2009, 08:51 am Last Edit: Jan 13, 2009, 08:51 am by vputz Reason: 1
Quote
It strikes me that you can buy 50' and even 100' shielded VGA cables.
...and as I mentioned above, you can make "VGA to Cat5" adapters (see the relevant bits from the instructable here).  I've run a video signal over a 200' patch cord using a couple of homemade adapters and it was a reasonably good signal.  So long as you don't need to rout it through switching equipment this would go through wall plugs, patch panels, etc.
Actually, that's a really funny idea--I'm not actually positive how well it would work, but I suspect it would work just fine--make some HD15-to-Cat5 adapters and some USB-to-cat5 adapters (I think you could put two USB signals through one wire, but not sure of distance), and then actually use a patch panel and two Cat5 jumpers (one for video, one for keyboard/mouse) to patch your keyboard/monitor to the computer you want to control.  Et voila!
Sounds pretty low-tech and cheesy, but you know I bet it would work, and no messy conversion to IP required if your cabling situation allowed it.
agent smith
of course this approach would be valid only if the servers are like in another room or floor in the same building, otherwise it's not practical.
And you would have the problem how to route the signal among more than one server. Arduino could handle the PS/2 / USB part, but the video signal?
kg4wsv
Quote
The question is are you switching the video signal using a mux with appropriate electrical characteristics?  The Arduino should be able to drive the select lines of said mux with no problems.
-j
0peace
Alright, my "final" conclusion is that it would be the easiest to put video cards (or any other way) to have composite output, and then have another server, that would have input that would be used more or less as a vnc proxy i am guessing...
It would be interesting to look inside one of those "KVM2ETHERNET" switches by epiphan systems, but I haven't had that much of a luck finding pictures online :-/
Oh well, I guess I will run back and forth for a while and when I will have more servers I will make a system like I explained above.
gnu_linux
I have
Had a PowerPC CPU inside, lots of flash chips, a large array of FPGA Chips, an ethernet chip and a bunch of other stuff :)
IIRC the FPGAs were Xilinx
And runs Linux of course :)
gnu_linux
0peace
Yeah... which still makes them pretty expensive... and I'm pretty sure that I'm sooo not on the level to  make my own chip.  :-/
gnu_linux
#22
Jan 17, 2009, 04:57 am Last Edit: Jan 17, 2009, 04:58 am by gnu_linux Reason: 1
I think the Altera FPGAs sell for about $10 each if you buy 10k units
Still expensive and a dev kit is probably very expensive
Most nicer embedded PPC boards I have seen are in the $600 to $1200 range
A $20 capture card and a few cheap VGAs with TV out will be a lot less expensive than a really nice IP KVM, a high end 16port IP KVM can easily go for $5,000 or $6,000 new
Avoid the cheap 1port IP KVMs they are usually very poorly made
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
