Topic: nRF24L01 Pins to ATMega328 (Read 4191 times) previous topic - next topic
velocity101
I'm trying out various tutorials on the nRF24L01 transceivers but in 99% of them, how to hook up the pins are hardly ever explained.  Being a newbie, I'm a bit lost.  Is it assumed that all the pins on the nRF24L01 are hooked up to the same corresponding pins on the Arduino (e.g. MOSI, MISO, SCK) but what about the CSN, CE and IRQ pins across all libraries for this transceiver?
I'm currently trying to figure out the "LED-Remote" tutorial by Maniacbug here:
http://arduino-info.wikispaces.com/nRF24L01-RF24-Examples
I'm assuming MOSI goes > MOSI, MISO > MISO, SCK > SCK, but what about the other pins?  In the setup, it specifies RF24 radio(9,10);  are these for CSN and CE?  If so, which pin is which?
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
// sets the role of this unit in hardware.  Connect to GND to be the 'led' board receiver
// Leave open to be the 'remote' transmitter
const int role_pin = A4;
// Pins on the remote for buttons
const uint8_t button_pins[] = { 2,3,4,5,6,7 };
const uint8_t num_button_pins = sizeof(button_pins);
// Pins on the LED board for LED's
const uint8_t led_pins[] = { 2,3,4,5,6,7 };
const uint8_t num_led_pins = sizeof(led_pins);
Complete code here: http://maniacbug.github.com/RF24/led_remote_8pde-example.html
iisfaq
Yes generally you are correct. The IRQ pin is not needed based on what I read.
My Transmitter does not have it connected, but I do hvae it connected on my Receiver but it seems to work.
I have recently been down this road and looking at the documentation really helps.
The docs are listed on the page you gave http://maniacbug.github.com/RF24/classRF24.html
http://maniacbug.github.com/RF24/classRF24.html#a8cd165a822c8f77e10782c6729c5b088
The first pin in the Constructor is the CE PIN followed by CS PIN
9 is CE Pin
10 is CS PIN (I assume also known as CSE)
These two pins seem to be able to be any general pins so 9 and 10 are not a hard coded set of pins.
CE = Chip Enable
CS = Chip Select
Hope this helps - I too am a newbe
chris
iisfaq
Also note that the pins are different on different hardware
See
http://arduino.cc/en/Main/arduinoBoardDuemilanove for Arduino Duemilanove
and for Arduino Mega 2560
http://arduino.cc/it/Main/ArduinoBoardMega2560
Chris
velocity101
This really helps. Thanks, Chris!
