Topic: Hot End Beginner Question (Read 798 times) previous topic - next topic
ekatzenstein
I've been trying to find online how to install a hotend for a reprap but have had no luck. I'd like to know how to properly wire a 3 wired hotend (one wire is a thermistor) to the electronics boards I'm using. I have an Arduino MEGA 2560 connected to a Quadstepper board (https://www.sparkfun.com/products/10507). Using neither RAMPS nor Gen6/7/etc. Will I need another board to run the extruder controller? Is there any way I can heat the hot end without having to place another order?
Lastly, is anyone aware of a good resource for hot end wiring directed towards a beginner?
Thanks for any help.
winner10920
What is a hot end or reprap?
the thermistor part is easy you'll just need another resistor to act as a voltage divider nd then read the voltage with analog read, perhaps buffer it a bit and average it out depending how noisy the enviroment is
Far-seeker
While Arduino's can be used as the control boards of RepRap and other 3D printers, I think you'll have better luck in an actual RepRap forum.  Also here's a link to the RepRap.org's wiki.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
