Topic: LEDs as Photo-diodes (Read 4444 times) previous topic - next topic
funkyguy4000
Hello,
I saw a few videos around the internet lately that were pretty nifty.  Using an led as a photo-diode.  I saw a thread and there was a link to the arduinos photo-diode tutorial although it didn't work for me for some reason.
Can anybody offer an awesome explanation or link me to a tutorial?
Accelerate to 88 miles per hour.
Tom Carpenter
They almost certainly weren't LEDs. The will have been phototransistors in an LED shape package.
The two behave totally differently as they use different sorts of semiconductor junction.
~Tom~
wanderson
Do a search for Forest M. Mims.
He has published a number of articles on using standard leds as photo diodes.  I have used a reverse biased green led connected to an osciliscope to measure the duration of a photographic flash unit like this
   9V
LED (reverse biased)
   +--- Oscilliscope
  1K resistor
Gnd
New true random number library available at: http://code.google.com/p/avr-hardware-random-number-generation/
Current version 1.0.1
Grumpy_Mike
#3
Aug 03, 2012, 12:30 am Last Edit: Aug 03, 2012, 07:59 am by Grumpy_Mike Reason: 1
They we're you know.
I have a page on it, in the workshop section
http://www.thebox.myzen.co.uk/Workshop/LED_Sensing.html
Tom Carpenter
I stand corrected. Finally a use for reverse biased LEDs!
~Tom~
fabelizer
Reversed biased leds do work as photo-diodes. Find below code that provides a solution to controlling leds from a led light detector. This can be a multilevel dark detector too!
/* LED_LIGHT_CONTROL_IBLE
* This program uses separate led's for light and sensing light.
* Works with room ambient or daylight.
* LED light sensing modified from Hunter's Instructible. Acheives sharp
* cut off and on according to "int light = X". Could also fade lights
* in/out on analog pins.
* Hunter Carlson
* June 9 2009
* Edits added Nov. 9, 2012 -fabelizer
* Requires at least 2 (or 3 or more) LEDs, one to analog pins 4 & 5, other
* to D8 & GND through a resistor. I used a water clear superbright
* red led for the sensor led, white for led1.
* See comments below for polarities and connections.
int sense01 = 5;        // sensing LED anode connected to analog pin5
int sense02 = 4;        // sensing LED cathode connected to analog pin4
                        // you can switch out different leds on these
                        // pins to see which works best. Run the
                        // serial monitor and watch the changes.
int LED01 = 8;          // LED anode to dig pin8, cathode to 220R
                        // 220R to GND.
int LED02 = 9;          // LED anode to dig pin9, cathode to 220R
                        // 220R to GND.
int val01 = 0;          // variable to store the value read from sense01
int val02 = 0;          // variable to store the value read from sense02
int light1 = 110;       // set light threshold for led1
int light2 = 80;        // set light threshold for led2
  Serial.begin(9600);        // setup serial (comment out to save memory)
  pinMode(LED01, OUTPUT);    // led1 pin set to output
  pinMode(LED02, OUTPUT);    // led2 pin set to output
  val01 = analogRead(sense01);      // read sense01 led
  val02 = analogRead(sense02);      // read sense02 led
   //debug print
  Serial.print(val01              // comment this section out to save memory
  Serial.println(val01-val02);    // result is printed and compared with light1 or 2
  Serial.println();               // blank line between values
                                    // first led 'led1'
if ((val01 - val02) >= light1) {   // check if light in area
      digitalWrite(LED01, LOW);     // if light enough, turn off led1
      digitalWrite(LED01, HIGH);    // if dark enough, turn on led1
                                    // second led 'led2'
if ((val01 - val02) >= light2) {   // check if light in area
      digitalWrite(LED02, LOW);     // if light enough, turn off led2
      digitalWrite(LED02, HIGH);    // if dark enough, turn on led2
delay(100);                         // just to slow things down a bit
-fab
Udo Klein
My page offers explanations plus links to the original research: http://blog.blinkenlight.net/experiments/measurements/led-camera/
You do not even need to reverse bias them. No matter in which direction you bypass them.
The reverse bypassing is only needed if you do not have an ADC but only digital inputs. With ADC inputs you can measure and find out that they work as photodiodes no matter how you bypass them.
dhenry
Folks at Mistubishi started this. Google their article.
AWOL
Keywords are Mitsubishi and iDropper.
Hippynerd
Heres an example of somone using an arduino, and LEDs as both lights, and sensors. The top corner LEDs are also sensors to control what the cube does.
https://www.youtube.com/watch?v=m3U-7cyNmFg
There is an instructible about it, and i think he did the whole 4x4x4 cube with no ICs (drivers or shift registers)
https://sites.google.com/site/rgbledcubes
dhenry
The approach proposed in the mistubishi paper is good for higher power led or at low lighting levels.
The charge transfer approach is good for regulator led or at high lighting levels. It is also simpler to implement and faster to run.
april
#11
Nov 13, 2012, 09:50 pm Last Edit: Nov 13, 2012, 10:05 pm by april Reason: 1
Just some links that seem pertinent
http://www.merl.com/areas/LEDcomm/  Original Mitsubishi article
http://arduino.cc/forum/index.php/topic,128556.0.html Thread I started ,didn't see this one
I could not find this ?
http://www.instructables.com/id/Bi-directional-LED-Sensing-Try-out/  Practical board and code setup
My code to play with this concept
const int led1 = A2;
const int led2 = A1;
int value1, value2;
int threshold1 = 120;
int threshold2 = 120;
void setup(){
 pinMode(led1,INPUT);
 pinMode(led2,INPUT);
void loop(){
 value1 = analogRead(A2);
 value2 = analogRead(A1);
 if(value1 >= threshold1){
   Serial.print("Value 1 : ");
   Serial.println(value1);
   out(led1,led2,threshold1);
 else if(value2 >= threshold2){
   Serial.print("Value 2 : ");
   Serial.println(value2);
   out(led2,led1,threshold2);
void out(int a, int b, int threshold){
 pinMode(b,OUTPUT);
 //if (a==led2)
 //delay(30);
 //else
 //delay(60);
 int value = analogRead(a);
   if(value >= threshold){
     analogWrite(b,value);
   else{analogWrite(b,0);    }
    Serial.print("Value Following: ");
dhenry
Not sure what your code is trying do but this is what I would try:
//read reverse of a led's cathode
unsigned short led_adc(unsigned char pin) {
  //energize the pin
  digitalWrite(pin, HIGH);
  pinMode(pin, OUTPUT);
  //put some delays here
  NOP(); NOP(); NOP(); NOP(); NOP();
  //adc the pin
  pinMode(pin, INPUT);
  return analogRead(pin);
void loop(){
  //read A1
  Serial.println(led_adc(A1));
  //out(led1,led2,threshold1);
  //pinMode(led2,INPUT);
  //read A2
  Serial.println(led_adc(A2));
led_adc() energies the led capacitance and then adc the charge transfer. For high led capacitance, you should read a voltage very close to 1023; Lower led capacitance results in lower reading - more charges are transfered to Chold -> lower voltage across the led capacitor.
dhenry
The charger transfer approach can be used as a way to measure small capacitance.
april
#14
Nov 14, 2012, 07:41 am Last Edit: Nov 14, 2012, 09:24 pm by april Reason: 1
Not sure what your code is trying do but this is what I would try:If you build it you will see an LED recognises the flash of another LED by flashing itself in the same sequence . So if I press the button on LED1 ,on and off the LED2 flashes on and off
 NOP(); NOP(); NOP(); NOP(); NOP();This does not compile. When I add in what is required to compile it with a delay(400) I get alternating  flashing LED's . So that's a bit vague , What are you trying to do and maybe I can help you
#define NOP() asm("nop") //waste a tick
void setup(){
Serial.begin(9600);}
 //energize the pin
delay(400);
 //adc the pin
void loop(){
 //read A1
 //read A2
