Topic: Arduino library for WTV020-SD-16P audio module (Read 278158 times) previous topic - next topic
ntmcguff
You do not use the diodes in the signal lines from the arduino to the RST/Din/Dclk lines. You need them in the vcc+ to the sound module to reduce the voltage to 3.3 vdc.
sopejonan
Even not needing them for the signals i don't think it is a good idea to use 5v signals for a 3.3V working peripheral no? I'm not sure of it as the datasheet of this chip is the worst i've ever seen...there is a lot of information missing there.
Although not needing the diodes for signal i've use the the way shown in the image i posted...and i can't understand the reason for them to work with that polarization...if someone could explain the reason i'll be very pleased
thanks a lot!
ntmcguff
#92
Feb 25, 2013, 10:06 pm Last Edit: Feb 25, 2013, 10:33 pm by ntmcguff Reason: 1
Here is my example of a Star Wars Blaster with 8 RGB LEDs, 3 74HC595 shift registers and the WTV020-SD-16P sound card. The sound files are from onesky.
74HC595 shift registers wiring: http://www.arduino.cc/en/Tutorial/ShiftOut
http://www.youtube.com/watch?v=CinD3UZLXz0
Code: [Select]
//  Name    : Blaster4                                          //
//  Author  : Norman McGuffey                                   //
//  Date    : 16 Feb 2013                                       //
//  Version : 1.0                                               //
//  Notes   : Code for using 3 74HC595 Shift Registers with     //
//          : 8 - 5mm Superbright CC RGB LEDs on E-11 Blaster   //
//          : Sound using WTV020-SD-16P microSD audio module    //
int resetPin2 = 2;  // Pin D2 connected to WTV20 /Reset (Pin 1)
int clockPin2 = 3;  // Pin D3 connected to WTV20 P04 (clock)(Pin 7)
int dataPin2 = 4;   // Pin D4 connected to WTV20 P05 (data)(Pin 10)
int button1Pin = 6; // Pin D6 connected to Trigger Switch
int button2Pin = 7; // Pin D7 connected to Select Switch
int latchPin = 8;   // Pin D8 connected to ST_CP (PIN 12)of 74HC595
int dataPin = 11;   // Pin D11 connected to DS (PIN 14) of 74HC595
int clockPin = 12;  // Pin D12 connected to SH_CP (PIN 11)of 74HC595
int LEDPin = 13;    // Pin D13 connected to LED
int button1State = 0;
int button2State = 0;
int button2Count = 1;
const unsigned int VOLUME_0 = 0xFFF0;
const unsigned int VOLUME_1 = 0xFFF1;
const unsigned int VOLUME_2 = 0xFFF2;
const unsigned int VOLUME_3 = 0xFFF3;
const unsigned int VOLUME_4 = 0xFFF4;
const unsigned int VOLUME_5 = 0xFFF5;
const unsigned int VOLUME_6 = 0xFFF6;
const unsigned int VOLUME_7 = 0xFFF7;
const unsigned int PLAY_PAUSE = 0xFFFE;
const unsigned int STOP = 0xFFFF;
byte dataRED;
byte dataGREEN;
byte dataBLUE;
int dataArrayRED[] = {1,8,64,0,0,0,0,0,0};
int dataArrayGREEN[] = {0,0,0,2,16,128,0,0,0};
int dataArrayBLUE[] = {0,0,0,0,0,0,4,32,0};
 pinMode(clockPin2, OUTPUT);
 pinMode(dataPin2, OUTPUT);
 pinMode(resetPin2, OUTPUT);
 pinMode(LEDPin, OUTPUT);
 digitalWrite(clockPin2, HIGH);
 digitalWrite(dataPin2, LOW);
 pinMode(latchPin, OUTPUT);
 pinMode(button1Pin, INPUT);
 pinMode(button2Pin, INPUT);
 digitalWrite(resetPin2, HIGH);
 delay(100);
 digitalWrite(resetPin2, LOW);
 delay(10);
 delay(100);
 sendCommand(0xFFF6);
 digitalWrite(LEDPin, HIGH);
 delay(50);
 digitalWrite(LEDPin, LOW);
 button2State = digitalRead(button2Pin);
 if (button2State == HIGH) {
   sendCommand(0x000);
   button2Count = button2Count +1;
   if (button2Count > 5) {
     button2Count = 1;
   for (int x=0; x < button2Count; x++){
      delay(100);
      delay(200);
 button1State = digitalRead(button1Pin);
 if (button1State == HIGH) {
  switch (button2Count) {
  case 1:
     { // Color = Red
     sendCommand(0x001);
     int dataArrayBLUE[] = {32,32,32,32,32,32,36,32,0};
     for (int j = 0; j < 9; j++) {
        dataRED = dataArrayRED[j];
        dataGREEN = dataArrayGREEN[j];
        dataBLUE = dataArrayBLUE[j];
        digitalWrite(latchPin, 0);
        shiftOut(dataPin, clockPin, dataBLUE);
        shiftOut(dataPin, clockPin, dataGREEN);
        shiftOut(dataPin, clockPin, dataRED);
        digitalWrite(latchPin, 1);
        delay(60);}
      break;}
 case 2:
      { // Color = Blue
      sendCommand(0x002);
      int dataArrayRED[] = {4,32,0,0,0,0,0,0,0};
      int dataArrayGREEN[] = {0,0,1,8,64,0,0,0,0};
      int dataArrayBLUE[] = {128,128,128,128,128,130,144,128,0};
        delay(100);}
      break;}
   case 3:
      { // Color = Green
      sendCommand(0x003);
      int dataArrayRED[] = {2,16,128,0,0,0,0,0,0};
      int dataArrayGREEN[] = {0,0,0,4,32,0,0,0,0};
      int dataArrayBLUE[] = {64,64,64,64,64,65,72,64,0};
        delay(90);}
      break;}
   case 4:
      { // Color = Purple
      sendCommand(0x004);
      int dataArrayRED[] = {5,40,64,0,0,0,0,0,0};
      int dataArrayGREEN[] = {0,0,1,10,80,128,0,0,0};
      int dataArrayBLUE[] = {160,160,160,160,160,162,180,160,0};
        delay(90);}
      break;}
   case 5:
      { // Color = Orange
      sendCommand(0x005);
      int dataArrayRED[] = {3,24,192,0,0,0,0,0,0};
      int dataArrayGREEN[] = {0,0,0,6,48,128,0,0,0};
      int dataArrayBLUE[] = {96,96,96,96,96,97,108,96,0};
        delay(75);}
      break;}
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
 int i=0;
 int pinState;
 pinMode(myClockPin, OUTPUT);
 pinMode(myDataPin, OUTPUT);
 digitalWrite(myDataPin, 0);
 digitalWrite(myClockPin, 0);
 for (i=7; i>=0; i--)  {
   if ( myDataOut & (1<<i) ) {
     pinState= 1;
   else {
     pinState= 0;
   digitalWrite(myDataPin, pinState);
   digitalWrite(myClockPin, 1);
void blinkAll_3Bytes(int n, int d) {
 shiftOut(dataPin, clockPin, 0);
 delay(200);
 for (int x = 0; x < n; x++) {
   shiftOut(dataPin, clockPin, 1);
   delay(50);
   delay(200);
void sendCommand(int addr)
 digitalWrite(clockPin2, LOW);
 delay(2);
 for (int i=15; i>=0; i--)
   delayMicroseconds(200);
   if((addr>>i)&0x0001 >0)
       digitalWrite(dataPin2, HIGH);
   if(i>0)
   if(i>0)
 delay(30);
Waytronic-Jasmine
Hi the-rebel-agent,
Hats off for sharing your experience :)
I am going to play with the same module but decided to ask and get the pin diagram confirmed. I found the following application circuit for this device.
I believe the following is the way of identifying the pins. Can you please confirm? :)
/Chathuranga
Yes, the way of identifying the pins is right----waytronic -Jasmine. Manufacturer of WTV020-SD module
Waytronic-Jasmine
Nice Stuff :)
I will add my findings etc when I continue with my experiments. I am about to start :)
The Datasheet says the maximum supported size of the Card is 1GB. Is that so or could you be able to use a card with higher capacity? I cannot imagine a reason of limiting the size at 1 GB because generally the address spaces are larger than that..  :~
acctually it can support 2 GB,we have tested 2GB TF card,same use with 1GB TF card.some times manual will have something wrong,and we will revise them when we discover them.and welcome every one to help us point out them.
Waytronic-Jasmine
I  just got from China a board : V1.5 / 2012.01.12", and "5v  / 3.3v
The only successfully way to format my Nokia mirco SD 512 MB
was win / cmd(Admin) / diskpart .
( http://www.chip.de/bildergalerie/Windows-To-Go-So-laeuft-Windows-8-auf-USB-Sticks-und-Festplatten-Galerie_54926063.html)
Up to now I run the board stand alone.
OK Files:
- 000X.ad4
- 000x.wav   freq 12.000 Mono and -1dB
It is possible to run MP3 im stand alone modus ?
WTV020-SD module only can play WAV and AD4 file
Waytronic-Jasmine
Hello!
I have a question!
How to manually change modes on vtv020-sd-16p,all ekys are on/off(loop),key 5 group of voice...
Thanks!!!
I want to ask which control mode module do you use?for example ,If you buy 2-wire series mode can not us key 5 group of voice,control mode is fixed when we program main chip,and you need tell supplier what you want,i think they will give you correct control mode module.
Waytronic-Jasmine
I've been working with a Somo-14D recently on a lightsaber project.  I got it generally working until I realized that it couldn't do gapless playback.  The gap was very small, but very noticeable when going from a swing directly into a hum.
Do you know if this module can do gapless playback?  I know the two units are similar, I just don't know how similar.
Thanks!
yes,it is same.it use same main control chip( WTV020 chip) and same program.
about gapless playback,WTV020-SD 16P can not do that,SD card response need some time,and main control can not do so fast communicate with SD card.
How long does your sound,maybe you can try SPI flash solution,it will response faster than SD card.
EA3BIL
Shared it on gallery section. Look for v laser gun.
Sorry for this silly question.... but,   I'm unable to find the files.
Any ideas where have they gone ??
Gracias,
Rafa.
the-rebel-agent
http://arduino.cc/forum/index.php/topic,110328.msg1113991.html#msg1113991
EA3BIL
EA3BIL
For the experiences I've read about this module....
Could it be possible to Sumarize your experiences and configuration??
(I'm getting frustrated because of wrong SDs -I've already checked 4-)
Jumper : 3.3 or 5 v
SD: Brand, Size, Format...
AD4 files: Speed, Rate, etc...
I think this will be a really usefull way to help new users for this module to be sucessful on their attemps.
NOTE:
And... Why not have that information populated under its own topic. "Audio players", "WTV020-SD-16P"
ntmcguff
EA3BIL,
I am running my WTV020-SD-16P at 3.3 vdc powered from the arduino 5vdc with with 2 diodes to drop the voltage to 3.3 vdc on the vcc+ line.
I am using a Sandisk 1gb MicroSD card formatted to FAT16. You can go up to a 2gb card.
The speed and rate of the A4D files are listed in the earlier posts.
All the information you need should be contained in this series of posts. Go back to the first post and start reading. This is how I got mine to work.
onesky
Code: [Select]
//  Version : 1.0                                               //
byte dataRED;
byte dataGREEN;
byte dataBLUE;
 delay(100);
 delay(10);
 delay(100);
 delay(50);
   sendCommand(0x000);
     button2Count = 1;
      delay(100);
      delay(200);
  case 1:
     { // Color = Red
     sendCommand(0x001);
        delay(60);}
      break;}
 case 2:
      { // Color = Blue
      sendCommand(0x002);
        delay(100);}
      break;}
   case 3:
      { // Color = Green
      sendCommand(0x003);
        delay(90);}
      break;}
   case 4:
      { // Color = Purple
      sendCommand(0x004);
        delay(90);}
      break;}
   case 5:
      { // Color = Orange
      sendCommand(0x005);
        delay(75);}
      break;}
 int i=0;
 int pinState;
     pinState= 1;
   else {
     pinState= 0;
 delay(200);
   delay(50);
   delay(200);
 delay(2);
   if(i>0)
   if(i>0)
 delay(30);
very well!
did you post your video in whitearmor forum too?
http://www.whitearmor.net/forum/topic/19322-arduino-a-cheap-board-for-e11-blaster-effects/page__st__120
ntmcguff
onesky,
I posted on whitearmour forum in a new topic here:
http://www.whitearmor.net/forum/topic/23198-another-arduind-e-11-blaster-setup/
