Topic: RGB to HEX (Read 5402 times) previous topic - next topic
Tom Carpenter
#30
Aug 11, 2012, 07:54 pm Last Edit: Aug 11, 2012, 07:56 pm by Tom Carpenter Reason: 1
Thats because %d means an integer. %f means a floating point, however due to the way the arduino compiler is setup, floating point in the **printf functions is disabled.
For 1dp, you can do something like this:
float time = 0.1;
int exponent = (int)time; //exponent is the number to the left of the decimal point
time -= (float)exponent; //remove the exponent to leave just the fraction.
int fraction = (int)(time*10.0); //fraction is the 1st number to the right of the decimal point
char timechar[5] = {0};
sprintf(buffer,"%d.%d",exponent,fraction);
uoled.TextGraphic(5,40, 1, 150, 1, 1, timechar, 1);
~Tom~
niekwoo10
It gave me some errors during compiling so i had to change the code to this:
float someFloat;
float time = 0.1;
int exponent = (int)someFloat; //exponent is the number to the left of the decimal point
int fraction = (int)(someFloat*10.0); //fraction is the 1st number to the right of the decimal point
sprintf(timechar,"%d.%d",exponent,fraction);
But now it just prints "0.0" to the screen...
niekwoo10
Never mind, already figured it out. Thanks!
Tom Carpenter
Yeah sorry, that was me copying code and forgetting to change the variable names. You'll need to be using the version that I corrected, as the one in your post would always give 0.0 .
~Tom~
niekwoo10
I ran into a problem and i can't solve it.
I'm using this code:
while (counting == 1){
if(digitalRead(leftpin) == LOW){counting = 0;}
if(counting == 1){someFloat = (float) someFloat + 0.1;}
sprintf(timechar,"%d.%d Seconds",exponent,fraction);
delay(100);
And now when it's counting it does fine, until it reaches one second, after that it does this:
1.10
1.11
1.12
1.13
1.14
1.19
2.20
2.21
2.29
3.30
Does anybody know what is causing this?
AWOL
Yes; inappropriate use of "float".
PaulS
If someFloat is a float, there is no reason to cast it to a float.
The portion on the left of the decimal point is NOT the exponent. Really poor choice of name.
Multiplying someFloat by 10, without having removed the integer portion will NOT give you correct results.
Tom Carpenter
#37
Aug 15, 2012, 10:32 pm Last Edit: Aug 15, 2012, 10:44 pm by Tom Carpenter Reason: 1
Maybe a poor choice of words on my part, technically it should be integral (or integer if you prefer). But never mind.
The problem is:
should be:
someFloat-= (float)exponent; //remove the exponent to leave just the fraction.
You didn't look at the corrected version as I suggested.
~Tom~
GoForSmoke
not tested but I can spell cat without a dictionary:
float f = 12.3;
int a = f * 10.0;
int leftOfDec = (int) f;
int rightOfDec = a % 10;
Serial.print( leftOfDec );
Serial.print( "." );
Serial.print( rightOfDec );
Personally, I like to leave the floats out and if I need to work to 10ths I make my unit 10ths.
int f = 123; // as in 123 10ths
int leftOfDec = f / 10;
int rightOfDec = f % 10;
Serial.print( rightOfDec ); // prints out as 12.3 1's
That has advantages of running faster and never confusing 1 with .999999999 or similar.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
niekwoo10
Already figured it out, this is the new code i'm using:
int integral = (int)someFloat; //integral is the number to the left of the decimal point
int fraction = (int)((someFloat - integral)*10.0); //remove integral to leave just fraction, fraction is the 1st number to the right of the decimal point
sprintf(timechar,"%d.%d Seconds",integral,fraction);
And now my stopwatch function is working, thank you!
