Topic: help clock temperature code (Read 1 time) previous topic - next topic
muzza
hi im all new to this and would be most appreciative if sombody could help with this code for a clock temperature its giving me the error msg
clock:108: error: expected unqualified-id before '{' token
heres the code
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#define DS1307_I2C_ADDRESS 0x68
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 8;
#define ONE_WIRE_BUS 13
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer = { 0x28, 0x2B, 0x12, 0x0D, 0x04, 0x00, 0x00, 0xAC};
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
void setDateDs1307(byte second,
byte minute,
byte hour,
byte dayOfWeek,
byte dayMonth,
byte month,
byte year)
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.write(0);
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(dayOfWeek));
Wire.write(decToBcd(dayMonth));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.write(0x10);
Wire.endTransmission();
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayMonth,
byte *month,
byte *year)
Wire.write(0);
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f);
*dayOfWeek = bcdToDec(Wire.read());
*dayMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
sensors.begin();
sensors.setResolution(insideThermometer, 10);
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH);
lcd.begin(16,2);
lcd.clear();
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00) {
lcd.print("Error");
lcd.print(tempC);
{byte second, minute, hour, dayOfWeek, dayMonth, month, year;
Wire.begin();
second = 0;
minute = 42;
hour = 9;
dayOfWeek = 1;
dayMonth = 3;
month = 10;
year = 10;
lcd.begin(16, 2);
delay(2000);
sensors.requestTemperatures();
lcd.setCursor(0,0);
printTemperature(insideThermometer);
lcd.print(char(223));
lcd.print('C');
getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayMonth, &month, &year);
lcd.clear();
lcd.setCursor(7,0);
lcd.print(" ");
lcd.print(hour, DEC);
lcd.print(":");
if (minute<10)
lcd.print("0");
lcd.print(minute, DEC);
lcd.print(":");
if (second<10)
lcd.print("0");
lcd.print(second, DEC);
lcd.setCursor(0,1);
lcd.print(" ");
switch(dayOfWeek){
case 7:
lcd.print("Sun");
break;
case 1:
lcd.print("Mon");
break;
case 2:
lcd.print("Tue");
break;
case 3:
lcd.print("Wed");
break;
case 4:
lcd.print("Thu");
break;
case 5:
lcd.print("Fri");
break;
case 6:
lcd.print("Sat");
break;
lcd.print(" ");
lcd.print(" ");
lcd.print(dayMonth, DEC);
lcd.print("/");
lcd.print(month, DEC);
lcd.print("/20");
lcd.print(year, DEC);
dxw00d
That doesn't look right. It also agrees with auto-format's 'too many left curly braces' message. I think that should be a closing brace instead. I recommend the use of auto-format - Ctrl-t/Cmd-t.
Tom Carpenter
#2
Aug 04, 2012, 09:49 pm Last Edit: Aug 04, 2012, 09:52 pm by Tom Carpenter Reason: 1
The whole of this bit is just floating in the middle of nowhere and appears to serve no purpose.
Wire.begin();
second = 0;
minute = 42;
hour = 9;
dayOfWeek = 1;
dayMonth = 3;
month = 10;
year = 10;
lcd.begin(16, 2);
The next bit is not quite right either.
delay(2000);
lcd.setCursor(0,0);
lcd.print('C');
Should be:
[code]void loop(){
delay(2000);
lcd.setCursor(0,0);
lcd.print('C');
[/code]
~Tom~
muzza
dont want to sound dumb but im confused ive never messed with code before
muzza
PaulS
any more input still stuck
"I made some code changes. I won't tell you what they were. I still need help"
Perhaps, my rephrasing of your comment will help you see what you need to do.
muzza
changed a few bits but im not sure how this has affected its two codes combined getting these errors
clock:17: error: expected unqualified-id before '[' token
clock:109: error: expected unqualified-id before '{' token
clock:128: error: expected unqualified-id before '[' token
clock:138: error: expected unqualified-id before '{' token
#include <Wire.h>
#include <LiquidCrystal.h> // we need this library for the LCD commands
// Setup a oneWire instance to communicate with any OneWire devices
// Pass our oneWire reference to Dallas Temperature.
// Convert normal decimal numbers to binary coded decimal
// Convert binary coded decimal to normal decimal numbers
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers
void setDateDs1307(byte second, // 0-59
byte minute, // 0-59
byte hour, // 1-23
byte dayOfWeek, // 1-7
byte dayOfMonth, // 1-28/29/30/31
byte month, // 1-12
byte year) // 0-99
Wire.write(0);
Wire.write(decToBcd(second)); // 0 to bit 7 starts the clock
Wire.write(decToBcd(dayOfMonth));
Wire.write(0x10); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave
// Gets the date and time from the ds1307
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
// Reset the register pointer
Wire.write(0);
// A few of these need masks because certain bits are control bits
*hour = bcdToDec(Wire.read() & 0x3f); // Need to change this if 12 hour am/pm
*dayOfMonth = bcdToDec(Wire.read());
// Start up the library
sensors.begin();
// set the resolution to 10 bit (good enough?)
lcd.begin(16,2); // columns, rows. use 16,2 for a 16x2 LCD, etc.
lcd.clear(); // start with a blank screen
lcd.print("Error");
lcd.print(tempC);
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
Wire.begin();
// Change these values to what you want to set your clock to.
// You probably only want to set your clock once and then remove
// the setDateDs1307 call.
second = 0;
minute = 42;
hour = 9;
dayOfWeek = 1;
dayOfMonth = 3;
month = 10;
year = 10;
//setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
lcd.begin(16, 2); // tells Arduino the LCD dimensions
[code]void loop(){
delay(2000);
lcd.setCursor(0,0);
lcd.print('C');
getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
lcd.clear(); // clear LCD screen
lcd.setCursor(7,0);
lcd.print(" ");
lcd.print(":");
if (minute<10)
lcd.print("0");
lcd.print(":");
if (second<10)
lcd.print("0");
lcd.setCursor(0,1);
lcd.print(" ");
switch(dayOfWeek){
case 7:
lcd.print("Sun");
break;
case 1:
lcd.print("Mon");
break;
case 2:
lcd.print("Tue");
break;
case 3:
lcd.print("Wed");
break;
case 4:
lcd.print("Thu");
break;
case 5:
lcd.print("Fri");
break;
case 6:
lcd.print("Sat");
break;
lcd.print(" ");
lcd.print(" ");
lcd.print(dayOfMonth, DEC);
lcd.print("/");
lcd.print("/20");
[/code]
PeterH
You seem to have posted two copies of your code so it's hard to know exactly what code you're running.
For goodness' sake, please indent your code. It's like wading through molasses trying to follow the structure of that. For extra brownie points, put each { and } on a separate line with each matching pair indented by the same amount - that style is not universally used but is the one that makes the structure of your code most obvious.
muzza
the bottom set is the code im trying to use
ive never done any programming before hard to know where to start
PaulS
Start with following Peter's advice to put each { and } on it's own line. Then, use Tools + Auto Format to format the code. Then, post just the code you have questions about.
muzza
whats meant by on its own line ?
PaulS
Each
word
in
this
reply
is
on
its
own
line.
muzza
gotcha  :P
tidied up and auto formatted getting these errors now :
clock:18: error: expected unqualified-id before '[' token
clock:104: error: expected unqualified-id before '{' token
clock:123: error: expected unqualified-id before '[' token
clock:134: error: expected unqualified-id before '{' token
#include <Wire.h>
byte hour, // 1-23
byte month, // 1-12
byte year) // 0-99
  Wire.write(0);
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
  Wire.write(0);
  sensors.begin();
    lcd.print("Error");
  else {
    lcd.print(tempC);
  Wire.begin();
  second = 0;
  minute = 42;
  hour = 9;
  dayOfWeek = 1;
  dayOfMonth = 3;
  month = 10;
  year = 10;
[code]void loop()
  delay(2000);
  lcd.setCursor(0,0);
  lcd.print('C');
  lcd.setCursor(7,0);
  lcd.print(" ");
  lcd.print(":");
  if (minute<10)
    lcd.print("0");
  lcd.print(":");
  if (second<10)
    lcd.print("0");
  lcd.setCursor(0,1);
  lcd.print(" ");
  switch(dayOfWeek){
  case 7:
    lcd.print("Sun");
    break;
  case 1:
    lcd.print("Mon");
    break;
  case 2:
    lcd.print("Tue");
    break;
  case 3:
    lcd.print("Wed");
    break;
  case 4:
    lcd.print("Thu");
    break;
  case 5:
    lcd.print("Fri");
    break;
  case 6:
    lcd.print("Sat");
    break;
  lcd.print(" ");
  lcd.print(" ");
  lcd.print("/");
  lcd.print("/20");
[/code]
Tom Carpenter
[code]void loop() //Woops, somebody left a [code] tag behind, you need to remove that!
  delay(2000);
  lcd.setCursor(0,0);
  lcd.print('C');
}//These two brackets aren't needed as the next bit is part of loop()
[/code][/code]
~Tom~
lloyddean
#14
Aug 05, 2012, 08:48 pm Last Edit: Aug 05, 2012, 09:52 pm by lloyddean Reason: 1
Look for comments "MISSING FUNCTION NAME"
#include <Wire.h>
DeviceAddress insideThermometer = { 0x28, 0x2B, 0x12, 0x0D, 0x04, 0x00, 0x00, 0xAC };
   return ((val / 10 * 16) + (val % 10));
   return ((val / 16 * 10) + (val % 16));
void setDateDs1307(
   byte hour,          // 1-23
   byte month,         // 1-12
   byte year)          // 0-99
       Wire.write(0);
void getDateDs1307(
   byte* second,
   byte* minute,
   byte* hour,
   byte* dayOfWeek,
   byte* dayOfMonth,
   byte* month,
   byte* year)
       Wire.write(0);
   sensors.begin();
       lcd.print("Error");
       lcd.print(tempC);
// MISSING FUNCTION NAME
   Wire.begin();
   second = 0;
   minute = 42;
   hour = 9;
   dayOfWeek = 1;
   dayOfMonth = 3;
   month = 10;
   year = 10;
//  setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
   delay(2000);
   lcd.setCursor(0,0);
   lcd.print('C');
   lcd.setCursor(7,0);
   lcd.print(" ");
   lcd.print(":");
   if (minute < 10)
       lcd.print("0");
   lcd.print(":");
   if (second < 10)
       lcd.print("0");
   lcd.setCursor(0,1);
   lcd.print(" ");
   switch(dayOfWeek)
       case 7: lcd.print("Sun");   break;
       case 1: lcd.print("Mon");   break;
       case 2: lcd.print("Tue");   break;
       case 3: lcd.print("Wed");   break;
       case 4: lcd.print("Thu");   break;
       case 5: lcd.print("Fri");   break;
       case 6: lcd.print("Sat");   break;
   lcd.print(" ");
   lcd.print(" ");
   lcd.print("/");
   lcd.print("/20");
