Topic: getting rid of re-set button. (Read 1 time) previous topic - next topic
jonisonvespaa
hi
ive got a bare bones board assembled, im using a usb to ttl converter to download my programs to it, ive got a 100nf c fitted from pin 1 to gnd, i thought this mod got rid of the need of a re-set button?  mine doesnt seem to do this any ideas?
thank you
michael_x
Quote
This phrase is not complete clear to me.
You need the DSR ( DTR ) signal of your Serial  (usb to ttl converter) connected to Pin 1, and a pullup resistor, to trigger a reset before the sketch upload.
A reset button ( or a little wire to ground pin 1 manually ) is very convenient anyway.
Docedison
Also quite required unless you are the GOD of C and C++ on the Arduino... You Know... The one who Never makes a coding mistake...
I LOVE My Reset Button...
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
florinc
Quote
The 100nF capacitor should be between RTS line of the "usb to ttl converter" and Reset pin of the processor.
JoeN
#4
Aug 06, 2012, 03:24 am Last Edit: Aug 06, 2012, 03:27 am by JoeN Reason: 1
Disabling reset for reals  is something that is done more often on the ATTiny chips to get one more GPIO pin because they have so few.  Also, it is disabled when you put the chip into debugWIRE mode, something you would never do in the Arduino environment.  Unless you need to do one of these two things, I wouldn't recommend it.  For one thing, you can no longer program the chip until you put it in a programmer a reenable that fuse.  More info:
http://www.ladyada.net/learn/avr/fuses.html
DebugWIRE is the DWEN fuse.  RSTDISBL is the reset disable which buys you an extra GPIO pin.  Setting either will buy you a lot of headaches in addition to their stated purpose.
I will never ask you to do anything that I wouldn't do myself.
CrossRoads
I think the answer is Yes, you do not need the physical reset button.  I do not install one in many of my projects.
JoeN
If that is the case, hold that pin high otherwise the ATMega will never come up.
CrossRoads
The question wasn't about the pullup resistor tho, just the button.
MarkT
The chip has an internal pull-up on the RESET line.  Its a weak pull-up though (30 to 60k) so in a noisy environment an external pull-up will stiffen the signal.
CrossRoads
Atmel recommends several components for the reset line, depending on the environment:
10Kpullup resistor
Diode across the resistor
cap to ground
resistor in series with reset switch to ground.
Most arduinos only have the first two.
See section 3 and 3.1 of the attached.
oric_dan
OP mentioned a cap to ground, nothing about having the 10K pullup, which
probably should be in there.
One thing I do on my pcbs, even if not wanting a physical switch, is to include
2 pads for Rst and Gnd, where I can install a 2-pin 0.1" header. Then I can add
a shunt, and hold the Arduino in reset indefinitely. I find this to be 1000% useful.
florinc
Quote
Why would you need this?
Tumbleweed
Reading the OP's post, I think he meant getting rid of "using" the reset button, which florinc answered in post 3.
I always put one (.1uf cap between RTS and reset)in when using my FTDI Friend to upload sketches so I don't have to hit the reset button on every (frequent) reload.
TomJ
Einstein once said you don't really understand anything until you can explain it to your Grandmother
oric_dan
Quote
Many sketches blink lights or ping piezos or cycle servos, and it's a PITN
to listen to all of that going on while you're editing the sketch. Holding
in reset is easier than pulling the power plug.
Also, I often use the Arduino board's USB port to connect to other boards,
especially ones with XBee, and if you hold the Arduino chip in reset, then
you can daisy chain the RX/TX pins. [my workbench usually has jumpers
going off in all directions].
CrossRoads
Having a reset pin also comes in handy when you screw up and blast stuff out the Rx pin or Tx pin so the bootloader can't get a word in. Then hold in reset & release at the right time.
Just having Reset brought out to a header pin where you can attach one via jumper is enough to solve that.
