Tasmania - Australia
« Reply #15 on: October 25, 2012, 08:30:32 am » |
Nice to see development in this area.
Now I am doing much the same, except that my project incorporates the complete monitoring and control for both solar panel array as well as a micro-hydro system. I intend also to install a tracking system on the solar array, and am digging big hole in ground as we speak for a 8 metre or for you usa folks a 4x6' triangle mast tower.
Now what i noticed with your design that did strike me with some concern is potential problems with wind loading. With using pulleys and such, I tend to think that one good gust of wind and your belts would be snapped or slipped and your nice panel will then likely be a lovely weather cock. I am wondering, is this something you have thought about, or is the total surface area of your panels so small that it would not e effected by such a strong gust?
I will be using a good solid ram drive, similar to what is used for satellite dish positioning, welded steel frame and suitable bearings.
Also, someone mention using a RTC as a backup, that is a good idea. The system I am designing will not use light sensors for directional operation, but using NTP, network time protocol as my system is connected to the internet anyhow.
You have obviously spent a great deal of time making fantastic CAD drawings which makes it far easier to see and visualise your design. Looking forward to hearing of your results.
rockwallaby
nr Bundaberg, Australia
« Reply #16 on: October 25, 2012, 08:47:03 am » |
Wind loading can be a huge force, I would have a real good look at that. Speaking of having a good look, anyone doing this sort of thing should check out this thread on the Aussie electronics forum http://www.ozelecforum.com/viewtopic.php?f=33&t=108As for the second axis, I think most people reckon it's not worth automating, just go out every 2-3 months and adjust them. ______ Rob
Pakistan
« Reply #17 on: December 27, 2012, 04:46:19 am » |
i have worked on my own dual axis sun tracking system. It is menu driven and all the parameters can be set using 6-key keypad and LCD. Saving the parameters in EEPROM is added.
« Reply #18 on: December 27, 2012, 09:53:47 am » |
Nice Khalid, interesting blogs as well.
______ Rob
Pakistan
« Reply #19 on: December 27, 2012, 01:21:17 pm » |
Rob, Thank you. This blog happen just with the help of nice helpful guys like youl Regards
DELHI
« Reply #20 on: January 14, 2013, 08:26:19 am » |
I suggest to use following methods
1) SPA algorithm code that gives you the exact position of sun. 2) use Inclinometre to measure the inclination for reference input 3)use suitable linear actuator and motor drive , that can drive the load 4) use gps sensor for getting date and time 5) real time clock has been used to provide back up incase GPS fails
« Last Edit: January 14, 2013, 08:30:33 am by AMPS-N »
AMPS
Pakistan
« Reply #21 on: January 15, 2013, 05:52:30 am » |
Hi AMPS, The bad thing about the stepper and servo is: 1- The whole system got too much costly 2- You have always keep energize the system ( In case of stepper if you remove the power it will loose holding torque and accuracy may suffer)
When you have a low cost approach then why to complicate the things?
DELHI
« Reply #22 on: January 15, 2013, 06:04:17 am » |
@KHALID.
ITS MY OPINION , Main agenda is to provide track the sun . To measure the sun angle accurately for many years with 0.0003 deg. 2) for that time and date has to be accurate , so i suggested GPS and real time clock for keeping time accurate. 3) in ordered to measure the usually u can use potentiometer ckt after few year it will loss its accuracy, So i refereed Inclinometre 4) The person who are going to design the tracking system , He has to take care of the drive and driver unit. I suggested linear actuator and linear actuator drive for that assuming the tracking system for home or residental.
Even we are in to solar tracking system we are successfully running with arduino from past 3 years.
AMPS
Pakistan
« Reply #23 on: January 15, 2013, 08:08:50 am » |
@AMPS Actually if you use LEDs or LDRs then you have no worries of degradation. Both have long life.. In Solar Panel you no need that much accuracy. Question is why? If you move the panels at 0.003 degree interval, then you have to move each second the panel. This will at the end of the day consumes lot of Motor, its drivers and controllers energy. I am also running the solar panels for past year and i find the good accuracy in positioning of panels.
DELHI
« Reply #24 on: January 15, 2013, 08:19:37 am » |
@khalid
1)It all depend on programming technique, you can save power whenever motor is not being used 2) LDR are sensitive dust. When Some dust fall on it . it might not work. It need periodic maintenance 3) 0.003 deg mentioned is not per degree to moved in everyday. I mentioned because if we use simple code using LDR after year if you reading 30deg for particular time , U might degrade to + or - 5 degree after year on same time, If we calculate for long period track will be out of position.
« Last Edit: January 15, 2013, 08:21:11 am by AMPS-N »
AMPS
« Reply #25 on: March 12, 2013, 08:27:57 am » |
i made this project using bearings and mechanics of an old hard disk..... nice idea!
