Topic: Multiple Servo Control (Read 2974 times) previous topic - next topic
ebun91
I'm doing a project where I have to control multiple servos with one arduino. I have this code I used for one servo, but I don't know if it will work for more than one. What do I have to do? Can I just do the code over again and define more buttons? Here is the code. Thanks.
Code: [Select]
#include <Servo.h>
Servo myservo;
int pos = 0;
const int buttonPinleft = 2;
const int buttonPinright = 5;
int buttonStateleft = 0;
int buttonStateright = 0;
  pinMode(buttonPinleft, INPUT);
  pinMode(buttonPinright, INPUT);
  myservo.attach(9);
  buttonStateleft = digitalRead(buttonPinleft);
  buttonStateright = digitalRead(buttonPinright);
  if (pos<180) pos=180;
  if (pos>0) pos=0;
  if (buttonStateleft == HIGH) {
    pos += 5;
  if (buttonStateright == HIGH) {
    pos -= 5;
    myservo.write(pos);
    delay(0);
johnwasser
Create as many Servo objects as you need (up to the Arduino UNO limit of 12 or Arduino Mega limit of 48). Use the .attach() method to associate each Servo object with an output pin.
You can have as many buttons as you have spare digital pins.  If you run out of pins there are hardware ways to connect more buttons than pins.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
ebun91
ebun91
How do I connect more buttons than pins? I just realized that I will need a lot more pins than available. What do I have to do?
johnwasser
There are several choices.  The cheapest is probably the R/2R resistor ladder that changes your button pushes to voltages on an analog input.  Using that method, each of the 6 analog inputs can read at least four buttons (24 buttons total).
http://blog.littlebirdelectronics.com/tutorial-analog-input-for-multiple-buttons-pa
ebun91
I didn't understand how to make the R-2R circuit.
johnwasser
You follow the schematic diagram near the top of that page.  Note the use of 10 kOhm and 20 kOhm resistors: R and 2R.
ebun91
Oh. Didn't see that. Sorry. Thank you!
ebun91
One last thing. Is there any way to connect more servos than pins? For this, I need to connect 14 servos and 15 buttons. The buttons are taken care of, so I was wondering about the servos.
MichaelMeissner
#9
Aug 09, 2012, 03:28 am Last Edit: Aug 09, 2012, 03:32 am by MichaelMeissner Reason: 1
There are various add-on boards that can do this.  For example Pololu has Maestro controllers that can handle 18 and 24 servos.  I'm sure if you go to other robot shops (dfrobot, robotshop, etc.), you will see other brands.
johnwasser
Since 14 is more than the 12 the Arduino UNO can handle on its own you have two choices:
Arduino Mega which can handle 48 servos.  It has has 54 digital I/O pins so after the 14 servos you have about 40 pins left for buttons.
External servo drivers, as mentioned above.
ebun91
Thank you, but I'm confused. Let's say Servos 1 and 2 are connected to pins 1 and 2. And Buttons 1 and 2 are connected to Analog pin 1. I want to control Servo 1 with Button 1 and Servo 2 with Button 2. Will the Analog pin be able to tell the difference between the buttons, or will it just read the amount of input it is receiving?
johnwasser
Thank you, but I'm confused. Let's say Buttons 1 and 2 are connected to Analog pin 1. Will the Analog pin be able to tell the difference between the buttons, or will it just read the amount of input it is receiving?
The analog input pin will do what analog input pins do:  It will measure the voltage from 0V to 5V and return a number from 0 to 1023 to represent that voltage.  The voltage is controlled by which buttons are pressed.  If no buttons are pressed you should get the number 0.
You can press each combination of buttons and note the value you get.  Then you can use a look-up table to determine the combination of buttons from the value.  It won't be exact so just search the table for the closest match.  Once you have determined the combination of buttons that are pressed you can take that value apart and work on each button individually.
Of course you could switch to a Mega and skip all this analog stuff.  :)
ebun91
Yes, I might just get a Mega lol. Thank you.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
