Topic: Arduino counts per minute calculator? (Read 2547 times) previous topic - next topic
flamturpolt
Hello. I found a really simple schematic to make a Geiger counter clicker. For when I want to get the CPM, can I just override the clicker/LED and connect it to the Arduino for CPM calculation?
-FlamTurpolt
Grumpy_Mike
Without seeing the schematic there is no way anyone can tell you.
flamturpolt
Here's the schematic: http://www.mare.ee/indrek/geiger/#clicker
Grumpy_Mike
Connect the junction of the BC517 and the speaker to an arduino input. Also connect the ground to the arduino ground.
If you want to remove the LED and the speaker then replace them with a wire connecting the collector of the transistor to the junction of the resistor and capacitor.
flamturpolt
BroHogan
@flamturpolt
I've been writing Geiger counter SW for quite a while now. Indrek's circuit should work with what i have, when connected as Mike suggested. (It would connect to INT0 - pin 2) Your welcome to take a look at it on this page.
It uses a rolling average for CPM, and has lots of goodies. I expect it should just drop in. Should give you some ideas at the least.
John
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
flamturpolt
BroHogan
~ Clifford Stoll
