Author Topic: 2560 bootloader fail, Unknown status 0x00  (Read 1001 times)
301
I am a n00b
Hello: Trying to flash R3 bootloader to 2560, getting the following error... I'm using AVRISP mkII, i've tried the arduino AVRISP drivers, and other drivers. using Arduino IDE 1.0.0.
i have checked all my connections about 1000 times. i can't figure this out... Help!
C:\Users\killa\Desktop\arduino-1.0\hardware/tools/avr/bin/avrdude -CC:\Users\killa\Desktop\arduino-1.0\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Users\killa\Desktop\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200118395
avrdude: usbdev_open(): using read endpoint 0x82
avrdude: Sent: . [01]
avrdude: Recv: . [01] . [00] . [0a] A [41] V [56] R [52] I [49] S [53] P [50] _ [5f] M [4d] K [4b] 2 [32]
avrdude: stk500v2_getsync(): found AVRISP mkII programmer
         AVR Part                      : ATMEGA2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: AVRISP mkII
avrdude: Sent: . [03] . [90]
avrdude: Recv: . [03] . [00] . [01]
avrdude: Sent: . [03] . [91]
avrdude: Sent: . [03] . [92]
avrdude: Recv: . [03] . [00] . [0a]
         Hardware Version: 1
         Firmware Version Master : 1.10
avrdude: Sent: . [03] . [94]
avrdude: Recv: . [03] . [00] 2 [32]
         Vtarget         : 5.0 V
avrdude: Sent: . [03] . [98]
avrdude: Recv: . [03] . [00] . [06]
         SCK period      : 8.00 us
avrdude: Sent: . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00]
avrdude: Recv: . [10] . [c0]
avrdude: stk500v2_command(): command failed
avrdude: Sent: . [03] . [a1]
avrdude: Recv: . [03] . [00] . [00]
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: Unknown status 0x00
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: Sent: . [11] . [01] . [01]
avrdude: Recv: . [11] . [00]
avrdude done.  Thank you.
California
What COM Port is your MkII on?
301
I am a n00b
it is USB... i do not believe it has a com port... it is listed under "libUSB-Win32 Devices" in device manager right now...
i tried these drivers too: http://mightyohm.com/blog/2010/09/avrisp-mkii-libusb-drivers-for-windows-7-vista-x64/
same issue, 0x00, rc=-1
I had the same problem, and it turned out to be my reset line.  You cpuld try a 10kbigger resistor, and a 22pf cap on a breadboard.  The mkii pulls the reset to gnd at the beginning,  and if it can't you'll get the error
301
I am a n00b
i put an o-scope on the reset line, and saw that it was not being brought down properly. traced it back to a faulty AND gate i was using (so multiple things can reset the chip). ran a hard wire, and flashed no problem.
I guess the thing tripping me up the most, was error code 0x00 is supposed to mean nothings wrong according to AVR069: AVRISP mkII Communication Protocol, but rc=-1 definitely meant something was screwy.
i've read in many places that rc=-1 almost always means a wiring issue, and this case was no different smiley
I wish ardunio had verbose output enabled by default on everything
