Topic: SPI.transfer(-1) behavior (Read 965 times) previous topic - next topic
nemalk
Aug 06, 2012, 10:41 am Last Edit: Aug 06, 2012, 11:06 am by nemalk Reason: 1
Hi all,
I started playing around with a SPI real time clock board a (DS3234 from Sparkfun) and downloaded some libraries.
I am trying to figure out how the functions implemented actually works so I can customize/tweak them for my own need.
Can somebody explain to me what the instrution SPI.transfer(-1) is doing? Is it some kind of shift in the byte to read/write.
Thanks
Tom Carpenter
It sends the value 255 over the SPI, and returns a byte from the selected slave.
When you want to read something from a slave device, the master has to put 8 clock cycles onto the SCLK line to time the date coming from the device. To do this you send a dummy byte and read in the response. Usually the dummy byte is either 255 (-1) or 0.
Some devices use full duplex, so every byte you send, you recieve a valid byte at the same time, but in this case, I think it is half duplex (master sends dummy bytes to read in from the slave).
~Tom~
nemalk
Thanks Tom.
The code makes more sense for me now  :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
