Loading...
Pages: 1 [2]   Go Down
Author Topic: Setting up a really bare bones arduino  (Read 936 times)
Offline Offline
Jr. Member
View Profile
In real-life terms, a faster crystal means things execute faster - including delay() and milliseconds() - as well as serial I/O. If your software doesn't rely on time, you should be OK. (If you're debouncing buttons, you might want to increase the time by 20/16 to compensate.)
You can use a Uno to program and then move it over to your faster crystal board to run if you don't want to bother finding a bootloader that handles 20 MHz.
« Last Edit: September 06, 2012, 11:56:40 am by AndyCC » Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Back to the OP, there is a product called the RBBB arduino sold as a kit by Modern Device.
http://shop.moderndevice.com/products/rbbb-kit
It probably represents the practical minimum you can take an arduino down to without hitting problems.  A lot cheaper than a Uno but you need some form of external USB-ttl adapter to program it.  Quite fun to build even if you're a noob with a soldering iron.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
