Offline
Newbie
« on: August 07, 2012, 02:57:35 am » |
Hello Arduino folks! I've just started with a SLAM robot hobby project and I'm looking for a good and not too expensive distance sensor. I've already tried the Maxbotix ultrasound sensor and I've just realized that the measuringbeam gets to wide when I'm measuring at around 1 meter. Now I'm looking for some kind of laser distance meter instead but as far as I'm concerned they are very expensive if you would like to have a range from around 10 cm - 500cm? If you look at the sensors at robotshop like these ones http://www.robotshop.com/high-end-lasers-obstacle-detectors.html?lang=en-us, then the price goes high. There are several hardware stores in my country though which sell cheap distance laser meters considering the accuracy and the measuring spectrum. like this one for example http://www.clasohlson.com/uk/Cocraft-40-m-Laser-Distance-Meter/Pr408348000#moreinfo. I would like to ask you guys why these kind of laser distance meter like the ones from Cocraft are so cheap and why can't I buy one of those and pick out the laser meter and then integrate it with my arduiono(do you think that even would be possible?). Or is there anywhere I can buy that kind of laser distance meter without having to pick it out myself and figuring out which wire is doing what? Thanks so much! I really appreciate you guys who answer my sometimes childish questions, I really do  //Archelon
Logged
Montreal
Offline
Edison Member
Per aspera ad astra.
« Reply #1 on: August 07, 2012, 08:47:50 am » |
The difference in price between first and second links, is due difference in method of measurements. "Scanning" rangefinders, like a radars, outputs wide sector of distances, some of them gives a full 3D picture. Cheep one measure only distance to single spot/dot. Parallax sensor I only can see in first link , works as single dot device. why can't I buy one of those and pick out the laser meter and then integrate it with my arduiono(do you think that even would be possible?). Try it. I'd be greatly impressed, if you succeeded. Or is there anywhere I can buy that kind of laser distance meter without having to pick it out myself and figuring out which wire is doing what?
Parallax listed on robotshop is only available laser range finder for arduino platform I'm aware of. You can build your own, look for details / code in this link: http://coolarduino.wordpress.com/2011/12/07/arduino-laser-3d-tracking-range-finder/
Logged
Offline
Newbie
« Reply #2 on: August 07, 2012, 10:29:05 am » |
The difference in price between first and second links, is due difference in method of measurements. "Scanning" rangefinders, like a radars, outputs wide sector of distances, some of them gives a full 3D picture. Cheep one measure only distance to single spot/dot. Parallax sensor I only can see in first link , works as single dot device. why can't I buy one of those and pick out the laser meter and then integrate it with my arduiono(do you think that even would be possible?). Try it. I'd be greatly impressed, if you succeeded. I have after some hours of googling I found this component http://porcupineelectronics.com/Laserbotics.html that can convert the data from a Fluke 411D distance meter ( http://www.fluke.com/fluke/usen/Laser-Distance-Meters/411D.htm?PID=69331) to a computer or via Serial communication to an arduino. What do you think about that option? I'm not so familiar with serial communication yet but I'll manage it I think.
Logged
Montreal
Offline
Edison Member
« Reply #3 on: August 07, 2012, 11:56:48 am » |
It may work, though price of interface board is more than range finder itself. My guess, interface board software decodes LCD display messages, leaving laser sensor / processing out of the picture. Probably, there is no easy way to hack a core. Following their path, you even don't have to open range finder itself, just put a web-cam above and make video recognition from LSD display, I think it would be possible for $150 project budget, but I would not call it "integration".
Logged
Phoenix, Arizona USA
Offline
Faraday Member
Where's the beer?
« Reply #4 on: August 07, 2012, 09:53:16 pm » |
There aren't many options out there for low-cost 2D LIDAR systems. The difference in cost generally is due to a number of reasons; for instance, the expensive sensors you see out there can scan very quickly, spit the data out quickly, work well in a variety of lighting conditions (up to and including daylight), use high-quality optics and lasers (plus IR filters and other systems to remove noise caused by other IR sources that can drown out the laser light), and they also generally use a form of interferometry to calc the distance (basically, you modulate the beam with a wave in the GHz range, and compare the outgoing beam with the reflected version - the difference between the waves is proportional to the distance measured - but you need really high speed timer circuitry for this). Some high-end sensors (so called LIDAR cameras) use time-of-flight and special high-speed optical sensors and timers to measure the time it takes from laser emission to reception of the reflected beam. All of that adds up to dollars. Every other low-cost method (including "real" - vs cheap "ultrasonic" - laser distance measuring devices) uses triangulation to measure the distance. You have a laser, then you have a sensor - usually a linear CCD or similar array, and the baseline between the two is known; using this information and some simple trig, you can calculate how far away an object the laser reflects off is by where the beam is detected on the linear array. This method suffers from low accuracy (because you can only get so many pixels in a linear array), and the need for the device to be manufactured fairly well so that the sensor can "see" what the laser is aimed at. Even so, it tends to be a cheap way to implement a range finder. That said, here's a breakdown: 1) A SICK, Hokuyo (or other expensive vendor) 2D LIDAR (~ $1000.00+ USD, depending on how you source it) 2) Ripping the sensor out of a Neato XV-11 vacuum cleaner robot and "hacking it" (~$400.00 USD) 3) The Parallax 1D LIDAR sensor (~$130.00 USD) - mount on a servo to pan it, for 2D sensing (somewhat slow) 4) Homebrew (??? USD) Item 1 is basically out of most people's budget; you've already indicated it isn't for you (but hey - I have seen sensors of this nature, in used condition, go for as low as $800.00 on Ebay - so maybe you might consider it if you want something much better). Likely - item 2 will be your best bet; there are a few sites out there that detail how to "hack" these and use them with an Arduino and/or other microcontrollers. You basically do some simple serial comms with them, and they spit out an approximate "360 degree" measurement list; whether the sensor works well in daylight is unknown (but I would guess: not very likely). Item 3 is a good deal because it basically does what most homebrew systems do - via a "parallax" method as described above, and does the processing of distance measured and such on-board, so you don't have to do much to interface to it. Add a nice servo to pan it around (mount it with the long-axis "up" to keep the servo mass down), and you can have a nice and fairly fast 2D LIDAR system (certainly at least as fast as an ultrasonic sensor with the NewPing library - but probably much faster is possible). Lastly - Item 4 - homebrew - is an option. What you are suggesting with the serial communications system is certainly possible; I would see if the serial output is already in some TTL serial (5V or 3.3V) format, first (instead of going through a special interface cable). How fast you can make those measurements, though, would be a question to find out about. Or - you can go "true homebrew" - here's a couple of ways of doing it - the first requires a PC and a webcam, the second can be done (in theory) with an Arduino or similar, but is not for the faint of heart, and the third can definitely be done with an Arduino. All use variations on the parallax geometry measurement methodology, in different forms (the second being the most complex - while the third is interesting in that it scans the laser, and keep the single phototransistor stationary - in effect, giving you a virtual linear "ccd" array): https://sites.google.com/site/todddanko/home/webcam_laser_rangerhttp://www.seattlerobotics.org/encoder/200110/vision.htm (you may have to refresh this one a couple of times to get it to fully load all the images) http://letsmakerobots.com/node/2651Hope these links help - I've answered this question so many times, and nothing has really changed much over the last couple of years; I think I am going to make a post of this on my web site, just so I can point there in the future...
« Last Edit: August 07, 2012, 10:01:53 pm by cr0sh »
Logged
Offline
Faraday Member
Where's the beer?
« Reply #5 on: August 07, 2012, 11:19:20 pm » |
Well - I went and wrote up an article for my website. It's basically the same as above, but I did add some extra links for other methods/ideas - so you may want to check it out: phoenixgarage.org || Low Cost LIDAR and Laser Range Finders: Where Are They?Hope this link doesn't offend anyone (mods, let me know and I'll remove it)...
Logged
Offline
Newbie
« Reply #6 on: August 08, 2012, 04:09:04 am » |
That sounds right! That's a good idea to put a webcam on top of it and I think it would work out quite good but the problem is that I just want to use the arduino and not a computer to get the distance data. As far as I'm concerned arduino can't handle graphic data that well
Logged
Offline
Newbie
« Reply #7 on: August 08, 2012, 04:29:16 am » |
Thanks for your reply cr0sh! You give a few options which sounds great but I'll think I'll go for the laser distance meter FLUX 411D and the onterface board I talked about earlier. I think the total cost for that "system" would be around 350 USD and I suppose it would work just as fine as the vaccum cleaner option if I attach it to a servo. I do also think it will work quite well in daylight as well, what do you think? And while I'm writing I must ask you cr0sh, you wrote this homebrew - is an option. What you are suggesting with the serial communications system is certainly possible; I would see if the serial output is already in some TTL serial (5V or 3.3V) format, first (instead of going through a special interface cable). How fast you can make those measurements, though, would be a question to find out about. what do you mean by TTL serial? in the interface board data sheet ( http://porcupineelectronics.com/uploads/LR3_Data_Sheet.pdf) it says that the RX and TX uses 3V signaling. does that mean that I have to power the arduino in some special way?
Logged
Montreal
Offline
Edison Member
« Reply #8 on: August 08, 2012, 10:20:57 am » |
I just want to use the arduino and not a computer to get the distance data. As far as I'm concerned arduino can't handle graphic data that well Right, interface web-cam to arduino would be problematic. Same time I can't imagine application where arduino would need +-3 mm distance measurements data over distance 50 m, plus 2D. There is no memory even to keep this information, not to do anything useful. I also have no clue, why this guys use 2D scan (using complex and high price mechanical hardware) for vacuum cleaner, when for simple obstacle avoidance you only need couple laser pointers ($2) and video cam (could be low as $10). http://coolarduino.wordpress.com/2012/07/28/visual-navigator-making-it-mobile/
Logged
Offline
Faraday Member
Where's the beer?
« Reply #9 on: August 08, 2012, 09:54:42 pm » |
I can't say anything as far as whether it would work well in the daylight or not, but it will probably be at least as good as any of the other low-cost options. It does say it's designed for outdoor use, so maybe it will work OK. Likely, it will work better for distance than the XV-11 sensor (it's distance is limited), but I doubt you'll get the same speed; the XV-11 spins 360 degrees quite rapidly (I think it can scan 10 full turns a second or so?); whereas that Fluke meter is going to have quite a bit of mass to move back and forth. I guess it will depend on how many scans you need and how fast your robot will be moving. There is also the possibility that it might be inaccurate (?) at close ranges vs. longer ranges. Something to keep in mind. And while I'm writing I must ask you cr0sh, you wrote this homebrew - is an option. What you are suggesting with the serial communications system is certainly possible; I would see if the serial output is already in some TTL serial (5V or 3.3V) format, first (instead of going through a special interface cable). How fast you can make those measurements, though, would be a question to find out about. what do you mean by TTL serial? in the interface board data sheet ( http://porcupineelectronics.com/uploads/LR3_Data_Sheet.pdf) it says that the RX and TX uses 3V signaling. does that mean that I have to power the arduino in some special way? Well - that board runs on 3 volts and outputs a USB signal; given that, it is likely that the meter itself is a 3.3 volt TTL logic device (that is, 3.3 volt = HIGH and 0 volt = LOW; the Arduino is a 5 volt TTL device - 5 volt = HIGH, 0 volt = LOW); instead of going from the meter's 3 volt TTL logic to USB then having to (somehow) convert that to something the Arduino can understand, it would be far simpler (assuming you can find the proper interface points) to just tap the 3 volt TTL serial signal from the meter directly, and forgo using the interface board (this would of course depend on what kind of connector and/or how that board hooks up to the meter). There may be some solder points directly on the meter's PCB that you could solder wires to. You would, of course, need to do level conversion for the signals to use them with the Arduino's 5 volt TTL levels, but there are plenty of solutions for that. Otherwise, that converter board is designed to be plugged into a PC (and likely appears as a virtual COM port to the PC - if you can identify what TTL serial to USB chip it uses, and get the datasheet for that, you might be able to tap the signals easily from there). The only way you can get away from -not- doing level conversion with the Arduino is to run it on 3 volts; unfortunately (IIRC), a standard Arduino - to run it at 3 volts - means you have to use the internal oscillator @ 8 MHz (which means you can't use the bootloader any more - so you have to program via ICSP).
Logged
Offline
Faraday Member
Where's the beer?
« Reply #10 on: August 08, 2012, 09:59:25 pm » |
I also have no clue, why this guys use 2D scan (using complex and high price mechanical hardware) for vacuum cleaner, when for simple obstacle avoidance you only need couple laser pointers ($2) and video cam (could be low as $10). 1) The hardware isn't expensive - Neato, when they announced the XV-11 - said the sensor could be made available to hobbyists for $25.00 (then they reneged on the deal). I doubt the sensor -is- $25.00, but I could see $100.00 - in manufactured quantities for their robot. 2) They aren't doing just obstacle avoidance. If you have ever watched an XV-11 vacuum, compared to a Roomba it is very, very intelligent. It makes proper "back-and-forth" straight carpet lines, not random patterns like the Roomba. It maps the room; likely it maps the house to a certain level, to know which and where what rooms needs to be done and when. It is apparently doing way more than just obstacle avoidance.
Logged
Offline
Newbie
« Reply #11 on: August 09, 2012, 03:53:13 am » |
Okay so I have to use some kind of logic level converter ( like this one? https://www.sparkfun.com/products/8745) between arduino and the interface board? I dont think skipping the interface board is an option for me because then I somehow have to decode the message the meter sends to the display. but as they write on the Interface board website "I'm planning on using the LR3 with an embedded microcontroller, is there a more simple way to interface than using the USB port? The LR3 has a logic level serial port - see the LR3 data sheet (above) for details. You can connect +5V, Gnd, Rx, and Tx to the LR3 and easily interface the LR3 with Arduino, PIC, or any embedded processor that has a serial port. Note: The LR3's serial port is not a full 12V RS232 compatible interface. If you are interfacing the LR3 to a standard RS232 port, then you will need to use a MAX3232 type level shifter." So I dont have to go through the USB port, I can use the Tx and Rx connections on the interface board. I'm thinking of putting the meter on a servo and measure the distance every degree or so and slowly build up a map. I now it wont be fast but thats okay, speed costs even more money
Logged
Offline
Faraday Member
Where's the beer?
« Reply #12 on: August 09, 2012, 11:31:30 pm » |
No - I was meaning between the Arduino and the meter - because that is all the LR3 is likely doing. It is (likely) simply doing a similar 3.3v to 5v logic level conversion and then applying that to a serial-to-usb converter chip (that, or the logic level shifting is being handled by the chip as well). I dont think skipping the interface board is an option for me because then I somehow have to decode the message the meter sends to the display.
I may be wrong, but I don't think that LR3 board is doing anything intelligent - I think all it does is conversion from TTL serial to USB (much like the chip on the Arduino). but as they write on the Interface board website "I'm planning on using the LR3 with an embedded microcontroller, is there a more simple way to interface than using the USB port? The LR3 has a logic level serial port - see the LR3 data sheet (above) for details. You can connect +5V, Gnd, Rx, and Tx to the LR3 and easily interface the LR3 with Arduino, PIC, or any embedded processor that has a serial port. Note: The LR3's serial port is not a full 12V RS232 compatible interface. If you are interfacing the LR3 to a standard RS232 port, then you will need to use a MAX3232 type level shifter." So I dont have to go through the USB port, I can use the Tx and Rx connections on the interface board.
Well - if it supplies that, and the LR3 doesn't cost gobs of money - then it may be the best bet. I just like to cut out the middle man when I can; I'd take the meter, find the connector, then open the meter up and trace the leads from the connector to some solderable point on the PCB, and hook my own wires in, then add the level shifting (which, depending on whether the communication is bidirectional or not, may or may not even be needed!). If the level shifting components ended up costing more than the LR3, though - it probably isn't worth it. I'm thinking of putting the meter on a servo and measure the distance every degree or so and slowly build up a map. I now it wont be fast but thats okay, speed costs even more money  If you can somehow decrease the mass of the unit attached to the servo (like decoupling the sensor head from the PCB in the meter, perhaps), you might be able to scan faster. Another possibility (though this may or may not work well - you might try it, though!) would be to point the meter at a small mirror (best would be an anodized gold first-surface mirror) mounted on the servo, then move the mirror instead of the entire meter...
Logged
Offline
Edison Member
If you're not living on the Edge, you're taking up too much space!
« Reply #13 on: August 13, 2012, 09:09:40 am » |
I'm doing something similar with my Canon DSLR and IR laser, in the dark. How does this work? It has a range of >100m!
Logged
If you fall... I'll be there for you! -Floor
Skype Brighteyes3333 (262) 696-9619
Offline
Faraday Member
Where's the beer?
« Reply #14 on: August 13, 2012, 10:35:25 pm » |
I'm not sure I follow what you mean - can you restate the question...?
Logged
