Topic: Arduino Leonardo ERROR compilling on WIN XP and WIN 7 (Read 640 times) previous topic - next topic
xrosas
Aug 07, 2012, 10:32 am Last Edit: Aug 07, 2012, 10:47 am by xrosas Reason: 1
ERROR compilling.
In file included from D:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino/HardwareSerial.h:66,
                from D:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino/Arduino.h:193,
                from ultraS_2dig.cpp:5:
D:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino/USBAPI.h:158: error: expected ',' or '...' before numeric constant
D:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino/USBAPI.h:188: error: expected ',' or '...' before numeric constant
D:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino/USBAPI.h:189: error: expected ',' or '...' before numeric constant
Code: [Select]
define clock 8
#define data 9
#define dimm 10
const int VIS1=11;
#include <Ultrasonic.h>
Ultrasonic ultrasonic(4,5);
int distancia = 0;
int distancia_ = 0;
int Mdistancia = 0;
int o_chan = 0;
int led = 13;
int brillo = 250;
int segs[10] ={63, 6, 91, 79, 102, 109, 124, 07, 127, 103};
int unidade = 0;
int decena = 0;
byte punto = B10000000;
byte nada = B00000000;
  pinMode(VIS1, OUTPUT);  // VIS1
  pinMode(clock, OUTPUT);
  pinMode(data , OUTPUT);
  pinMode(dimm , OUTPUT);
  pinMode(led , OUTPUT);
  analogWrite(dimm, brillo);
  axuste();
   Serial.println("Preparado");
  if ( o_chan > 99) digitalWrite(VIS1, HIGH);
    else digitalWrite(VIS1, LOW);
  distancia = o_chan;        //só para poder pintalo
  pinta();
  atenua();
  distancia_ = distancia;
xrosas
Rename
Code: [Select]
//#define clock 8
//#define data 9
//#define dimm 10
For
Code: [Select]
const int clock= 8;
const int data= 9;
const int dimm= 10;
And eliminate Serial.begin(9600);
works
