Loading...
Pages: [1]   Go Down
Author Topic: SparkFun 5110 84x48 LCD supply voltage  (Read 687 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
Hi I am using this lcd, but I want to solder it permanently rather than using a breadboard, however I am getting mixed thoguhts as to whether the VCC line can and should/should not be 5v.
This diagram from the quick start guide says its ok - and thats the one Ive been using, however if Im going to make it permanent I want to know whats best:
http://sfecdn.s3.amazonaws.com/tutorialimages/GraphicLCDLandingPage/LCD2.jpg
Thats shows 5v to vcc. Should it be 3.3v for better care of the lcd, or should I connect it througha  resistor? I have the leds on a 3.3v supply with a resistor in place.
If I should be using a resistor, what size should I use?
Thanks
Logged
Offline Offline
Jr. Member
View Profile
i guess that diagram is ok but if you are not sure (btw. i'm not sure either) connect the lcd to 3.3v and if it is not gonna work then try 5v.
Logged
Offline Offline
Newbie
View Profile
I looked at the datasheet from spark fun and it shows this lCD is a 3.3Volt so you may fry it if you hook it up to 5 volts.
VDD1 supply voltage 1 LCD voltage externally
supplied (voltage generator
disabled)
2.7 - 3.3 V
VDD2 supply voltage 2 LCD voltage internally
generated (voltage
generator enabled)
2.7 - 3.3 V
Logged
ottawa, canada
Offline Offline
God Member
Arduino rocks
View Profile
I run mine at 3.3 using a small red led to drop the voltage. The current draw is very small so the led's barely visibly lit.
Logged
Pages: [1]   Go Up
Print
Jump to:
