Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Found a place for cheap pcb manufacturing  (Read 9187 times)
Portugal
Offline Offline
God Member
Tomorrow I will know a BIT more than yesterday
View Profile
Thanks it really simplify my problem.
In your opinion, when run the DRC check I get a lot of warnings about "stop mask".Can I ignore this warning?
Logged
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
If you are happy with your reference designator placements (R1, R2, C1, etc) and anything else you have on the Names layers (25 & 26), then you can ignore them.  I try and place all names so they don't overlap vias, pads, holes, and also the place markings for parts. You can right-click a part, SMASH it, and then move names, change their properties for size, font, etc.
Review the gerber files, you see can see what will end up the top & bottom for stenciling.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Smithfield, Rhode Island
Offline Offline
God Member
View Profile
Is that what all my "stop mask" errors are? Silk screen that overlaps something?
Logged
Offline Offline
God Member
View Profile
After a bit of digging I found a place for super cheap PCB manufacturing.
http://www.oshpark.com/
I just checked their site, and one thing worth pointing out is that their boards are all ENIG, which means gold immersion. I order all my boards ENIG because I believe its well worth the extra expense. So if you compare prices to this place be sure the place you're comparing to also is quoting ENIG.
I have been happy with International Circuits, but that does not mean I won't at least look ;-)
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
"Is that what all my "stop mask" errors are? Silk screen that overlaps something? "
Yep.  Large qty of them will be the outlines around connectors for instance.
Logged
Offline Offline
God Member
View Profile
So then all the slik screen is going to make an error, since its all on the stop mask.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I wouldn't worry about it as long as your Ref Des #s are clear and not intefering with connector markings or parts placement markings.
Logged
Nova Scotia
Offline Offline
Full Member
View Profile
WWW
My first post mentioned that I ordered my boards from: http://www.oshpark.com/ It's been a while and since then the boards came in, have been populated and my layout is up and running. Manufacturing them and delivery took around 30 days but if you are in no rush then do recommend them. The quality is great for prototype boards. The drill hole alignment on the pads was well centered but the silkscreen was off a bit only on the backside. No worries there as long as the drill holes are good.
This was my first custom board so dropping the bootloader on was interesting. It turned out to be easier then what I was expecting. In my world, that never happens.
Check it out at:
https://sites.google.com/site/0miker0/Designing-your-custom-Arduino-Board
Logged
Offline Offline
Jr. Member
View Profile
Not exactly.  The stop mask layer is a negative layer.  IOW, it indicates where the solder mask will not be.  Ideally, there wouldn't be any overlap between the silkscreen and the solder mask layers.
Logged
Leighton Buzzard, UK
Offline Offline
Edison Member
View Profile
I found that using vector instead of proportional text dramatically reduced the number of spurious stop mask error reports
my guess is that proportional defines a rectangle to hold the text
if that rectangle crosses a stop mask - ALARM ALARM the world is falling in
by converting the text to vector is just moans where there's a real problem
basically you don't want the silk screen printing on top of where you're trying to solder
IMHO YMMV
Logged
there are only 10 types of people
them that understands binary
and them that doesn't
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Like I said: "I wouldn't worry about it as long as your Ref Des #s are clear and not intefering with connector markings or parts placement markings."
I personally think proportional ends up looking better.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
One debugging step I have learned the hard way is to view only layer 19 the unrouted layer.  In a complex board you may not be able to see short unrouted air traces, by only showing the unrouted layer you of course can see them clearly if they are there.
Unrouted traces can occur if you route by hand or auto so I think this is a good debugging step.
wade
Logged
Canada
Offline Offline
Jr. Member
Frequently Befuddled
View Profile
WWW
wade
I so wish there were a way to include a test for airwires in the DFU rules. I accidentally sent a board off with an unrouted trace... d'oh! Though in the end it was an excuse to add a bit more functionality to the project with another revision, it was still an aggravating mistake.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Using the Rats Nest reports on the number of unrouted traces.
I change the color to yellow to make them easier to see.
The really little short traces right on top of  pad are the hardest to find.
Logged
Portugal
Offline Offline
God Member
View Profile
I order my boards at http://imall.iteadstudio.com/ but it almost passed 2 months and I'm still waiting.Does anyone already order boards on them and how did it take to deliver the boards?
I have more boards to send to fabrication but with this delay I need to find another pcb house.
My hope is to find a good one in Europe  smiley-cool
Logged
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Pages: 1 [2] 3   Go Up
Print
Jump to:
