Portugal
Tomorrow I will know a BIT more than yesterday
« Reply #15 on: August 20, 2012, 12:14:01 pm » |
Thanks it really simplify my problem. In your opinion, when run the DRC check I get a lot of warnings about "stop mask".Can I ignore this warning?
Debian,Mint,Ubuntu Arduino Mega 2560 Arduino Nano Arduino Duemilanove MAC OS Montain Lion Raspberry PI Model B
Boston area, metrowest
Online
« Reply #16 on: August 20, 2012, 01:51:17 pm » |
If you are happy with your reference designator placements (R1, R2, C1, etc) and anything else you have on the Names layers (25 & 26), then you can ignore them. I try and place all names so they don't overlap vias, pads, holes, and also the place markings for parts. You can right-click a part, SMASH it, and then move names, change their properties for size, font, etc.
Review the gerber files, you see can see what will end up the top & bottom for stenciling.
Smithfield, Rhode Island
« Reply #17 on: September 07, 2012, 07:48:17 pm » |
Is that what all my "stop mask" errors are? Silk screen that overlaps something?
« Reply #18 on: September 07, 2012, 07:55:15 pm » |
I just checked their site, and one thing worth pointing out is that their boards are all ENIG, which means gold immersion. I order all my boards ENIG because I believe its well worth the extra expense. So if you compare prices to this place be sure the place you're comparing to also is quoting ENIG. I have been happy with International Circuits, but that does not mean I won't at least look ;-)
Online
« Reply #19 on: September 08, 2012, 05:32:44 pm » |
"Is that what all my "stop mask" errors are? Silk screen that overlaps something? " Yep. Large qty of them will be the outlines around connectors for instance.
« Reply #20 on: September 08, 2012, 05:36:25 pm » |
So then all the slik screen is going to make an error, since its all on the stop mask.
Online
« Reply #21 on: September 08, 2012, 07:11:30 pm » |
I wouldn't worry about it as long as your Ref Des #s are clear and not intefering with connector markings or parts placement markings.
Nova Scotia
« Reply #22 on: October 10, 2012, 08:45:14 am » |
My first post mentioned that I ordered my boards from: http://www.oshpark.com/ It's been a while and since then the boards came in, have been populated and my layout is up and running. Manufacturing them and delivery took around 30 days but if you are in no rush then do recommend them. The quality is great for prototype boards. The drill hole alignment on the pads was well centered but the silkscreen was off a bit only on the backside. No worries there as long as the drill holes are good. This was my first custom board so dropping the bootloader on was interesting. It turned out to be easier then what I was expecting. In my world, that never happens. Check it out at: https://sites.google.com/site/0miker0/Designing-your-custom-Arduino-Board
« Reply #23 on: October 10, 2012, 10:30:42 am » |
So then all the slik screen is going to make an error, since its all on the stop mask. Not exactly. The stop mask layer is a negative layer. IOW, it indicates where the solder mask will not be. Ideally, there wouldn't be any overlap between the silkscreen and the solder mask layers.
Leighton Buzzard, UK
« Reply #24 on: October 10, 2012, 03:44:37 pm » |
I found that using vector instead of proportional text dramatically reduced the number of spurious stop mask error reports my guess is that proportional defines a rectangle to hold the text if that rectangle crosses a stop mask - ALARM ALARM the world is falling in by converting the text to vector is just moans where there's a real problem
basically you don't want the silk screen printing on top of where you're trying to solder IMHO YMMV
there are only 10 types of people them that understands binary and them that doesn't
Online
« Reply #25 on: October 10, 2012, 06:29:59 pm » |
Like I said: "I wouldn't worry about it as long as your Ref Des #s are clear and not intefering with connector markings or parts placement markings." I personally think proportional ends up looking better.
« Reply #26 on: October 17, 2012, 10:02:30 am » |
One debugging step I have learned the hard way is to view only layer 19 the unrouted layer. In a complex board you may not be able to see short unrouted air traces, by only showing the unrouted layer you of course can see them clearly if they are there.
Unrouted traces can occur if you route by hand or auto so I think this is a good debugging step.
wade
Canada
Frequently Befuddled
« Reply #27 on: October 17, 2012, 12:50:40 pm » |
wade
I so wish there were a way to include a test for airwires in the DFU rules. I accidentally sent a board off with an unrouted trace... d'oh! Though in the end it was an excuse to add a bit more functionality to the project with another revision, it was still an aggravating mistake.
Online
« Reply #28 on: October 17, 2012, 08:01:28 pm » |
Using the Rats Nest reports on the number of unrouted traces. I change the color to yellow to make them easier to see. The really little short traces right on top of pad are the hardest to find.
Portugal
« Reply #29 on: October 20, 2012, 04:27:37 pm » |
I order my boards at http://imall.iteadstudio.com/ but it almost passed 2 months and I'm still waiting.Does anyone already order boards on them and how did it take to deliver the boards? I have more boards to send to fabrication but with this delay I need to find another pcb house. My hope is to find a good one in Europe
