Viva,
Tenho o seguinte código:
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
// And pieces from Arduino Playground <http://www.arduino.cc/playground/Learning/PRFID>
// And then modified again by thekidd
// 12.04.2008 – Added interrupt to ensure program does not hang on RFID reader.
//NOTA:
//com este não foi possível ver o número do cartão.
#include <avr/interrupt.h>
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
#define ledPin 13
// set up a soft serial port
SoftwareSerial mySerial(rxPin, txPin);
int val = 0;
char code[10];
int bytesread = 0;
// define pin modes for tx, rx, led pins:
pinMode(rxPin, INPUT); // Set rxPin as INPUT to accept SOUT from RFID pin
pinMode(txPin, OUTPUT); // Set txPin as OUTPUT to connect it to the RFID /ENABLE pin
pinMode(ledPin, OUTPUT); // Let the user know whats up
// set the data rate for the serial ports
mySerial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
Serial.begin(9600); // Serial feedback for debugging in Wiring
// say something
Serial.println("Hello World!");
attachInterrupt(0, readRFID, CHANGE); // Setup interrupt for SOUT on RFID reader
digitalWrite(txPin, LOW); // Activate the RFID reader
// Do Something
void readRFID() {
digitalWrite(ledPin, LOW); // Turn off debug LED – Event triggered!
if((val = mySerial.read()) == 10) { // check for header
bytesread = 0;
while(bytesread<10) { // read 10 digit code
val = mySerial.read();
if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10) { // If 10 digit read is complete
digitalWrite(txPin, HIGH); // deactivate RFID reader
digitalWrite(ledPin, HIGH); // activate LED to show an RFID card was read
Serial.print("TAG code is: "); // possibly a good TAG
Serial.println(code); // print the TAG code
bytesread = 0;
O código acima lê um cartão/etiqueta e apresenta-o no monitor.
O meu problema é que aparece "YYYYYYYYYYY" no lugar de apresentar o número da etiqueta.
O que acham que está a correr mal?
Muito obrigado,
Qualquer dica será muito apreciada.
