Hi - first off I'm a huge newbie at both Arduino development and the Arduino forums, so mods please move this if it's not in the right place or something.
I'm trying to integrate Ken Shirriff's IR Remote library (available from his blog here
http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html) with the SparkFun ArduMoto motor shield (
https://www.sparkfun.com/products/9815). The test project I'm using is simple enough - it includes the IRRemote library, turns on recieving, then if it detects the hex code for the power button on the remote control I'm using it tries to power the motor. Unfortunately, the ArduMoto shield uses pins 3, 12, 13 and 11, with 13 and 3 using PWM for speed/power control. The IRRemote library, from what I've been able to glean from my research, uses the ATMega's internal timer2, which unfortunately precludes using pin 3 for PWM. This means that running irrecv.enableIRIn() means I can no longer control my motors.
I've thought of a couple possible solutions - the ideal would be updating the library to use the ATMega timer1 (although again from my limited research this looks like a 16-bit instead of an 8-bit timer, which might screw some stuff up?), unfortunately I don't really know how to go about doing this. Next up would be cutting the trace lines on the ArduMoto and soldering in some jump wires to the pins, but I'd rather not do that just for the sake of keeping all of the printed labels on the shield correct (I don't want to have to flip it over four times two weeks from now wondering "if I plug in to pin 10 here it's actually getting jumped to 7...or is that 6?"). The final option would be to just run the motor shield off of one Arduino and the IR receiver on another, with them communicating in some way (I'm assuming this would be pretty easy, I would have tested it already but my Leonardo board is being finicky). Again I'd prefer not to go this route because it seems like complete overkill, plus I'd need another power supply.
Some of my example code is below, I've tried to clean it up a bit while still getting the gist across. Motor A is commented out because I figured without using pin 3 I might be able to get the receiver working with just Motor B - sadly, no dice (incidentally I'm really curious as to why this is, I must be missing something. Ideas?).
Test project with IR Remote library and ArduMoto shield
#include <IRremote.h>
#define ON_CODE 0x61D648B7
#define MODE_STOP 0
#define MODE_FORWARD 1
//int pwm_a = 3;
int pwm_b = 11;
//int dir_a = 12;
int dir_b = 13;
int IRRecPin = 6;
int mode = MODE_STOP;
boolean isRunning = false;
IRrecv irrecv(IRRecPin);
decode_results results;
//pinMode(pwm_a, OUTPUT);
pinMode(pwm_b, OUTPUT);
//pinMode(dir_a, OUTPUT);
pinMode(dir_b, OUTPUT);
Serial.println("Initialized control pins");
irrecv.enableIRIn(); //enable the receiver, kill the motors....all in a day's work *sigh*
Serial.println("Initialized IR reciever");
//analogWrite(pwm_a, 150); //test running motors after enableIRIn() (won't work!!)
// analogWrite(pwm_b, 150);
if (irrecv.decode(&results)){ //catch results from the remote
Serial.print(results.value, HEX); //log it, make sure it's sane
if(results.value==ON_CODE){
// mode=MODE_FORWARD;
isRunning=true;
irrecv.resume(); //allows more IR input if I understand correctly
if (isRunning){
// digitalWrite(dir_a, HIGH);
//digitalWrite(dir_b, HIGH);
//analogWrite(pwm_a, 200);
analogWrite(pwm_b, 200);
Serial.println("Motors on"); //this will print to the serial monitor when the motors should be running but aren't
delay(1000); //just so we don't flood the serial monitor - hey, if we're at this point we're already 'on' and a second delay for the IR decoding doesn't matter much
Any thoughts/ideas/comments? All help is greatly appreciated!
