Topic: Problem powering more than one ESC with Battery Pack (Read 978 times) previous topic - next topic
GamecubePerson111
Alright, so I am powering two ESCs from a 14.8v 5A lipo battery pack and when I send a pulse width through the PWM pins, the voltage being sent to the ESCs drops all the way down to 2v and then 0v.  Is my battery pack insufficient?
retrolefty
You really should post your code. Hopefully you are using a servo library to output commands to the ESC?
Lefty
GamecubePerson111
Oh yeah here's my code:
Code: [Select]
#include <Servo.h>
Servo myservo1;  // first motor to be controlled by potentiometer
Servo myservo2;  // second motor to be controlled by potentiometer
int potpin = A0;  // analog pin used to connect the potentiometer
int potValue = 0;    // variable to read the value from the analog pin
int mappedValue = 0;    //variable to hold "mapped" value
#include <Servo.h>
  Serial.begin(9600);          //  setup serial
  myservo1.attach(6);  // attaches the servo on pin 9 to the servo object
  myservo2.attach(9);
  Serial.println("The count down");
  Serial.println("5");
  Serial.println("4");
  Serial.println("3");
  Serial.println("2");
  Serial.println("1");
  Serial.println("0");
  potValue = analogRead(potpin);    // reads the value of the potentiometer (value between 480 and 990)
  Serial.print("potValue = ");
  Serial.println(potValue);             // debug value
    mappedValue = map(potValue, 0, 1023, 0, 179);     // scale it to use it with the motor (value between 28 and 179)
  Serial.print("mappedValue = ");
  Serial.println(mappedValue);
  Serial.println(" ");
  myservo1.write(mappedValue);        // sets the motor speed according to the scaled value
  delay(125);                           // waits for the motor to gain speed
  myservo2.write(mappedValue);
  delay(125);
Magician
What kind of ESC, have a link? Arduino version? Wiring diagram?
GamecubePerson111
Wires the code:
http://www.hobbyking.com/hobbyking/store/__6459__Hobbyking_SS_Series_40_50A_ESC.html
I'm using an arduino duemilanove.
I can't post a diagram at the moment but I can say that I can get one motor working just fine, but I just can't get two to work.
GamecubePerson111
Sorry for the double post, I didn't see an edit button but that link is the ESC.
Magician
What I can tell, based on schematic provided on web-site, there is a resistor 4.7 k is series with PWM input of the controller. There is no reason for voltage to drop noticeable, and if it the case, than something wrong with wiring or ESC failed. ESC programmable, probably you should use manufacturer hot-line technical support.
GamecubePerson111
So there's really nothing else it could be?  I guess I also might try and find a new battery just incase.
GamecubePerson111
Would the C rating of the battery have any effect on this sort of stuff? I believe that is the discharge rate.
Far-seeker
#9
Aug 08, 2012, 11:32 pm Last Edit: Aug 09, 2012, 12:19 am by Far-seeker Reason: 1
Yes, C is the discharge rate.  However, I don't think that would be the issue.  The ESC's current rating is 40 A, unless your battery pack has a  Total Capacity / C Rating greater than 40 A it shouldn't be able to harm the ESC.
Edit: Originally typed the math wrong and didn't notice it. :smiley-red:
GamecubePerson111
Should I probably just buy a new battery? Because I was able to get working fine with one motor and one ESC.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
