Topic: Lumex LCR-U01602DSF/DWH 16×2 Backlit LCD Display Problems (Read 3880 times) previous topic - next topic
floresta
Quote
Quote
You must supply a voltage larger than 6.8 Volts in order to cause the LED to conduct
Did you mean to say 6.2 Volts?
Let me rephrase that.  You must supply a voltage larger than 6.8 Volts in order to be sure that the LED will conduct.
If the LED is 'nominal' it will conduct with a voltage greater than 6.2 Volts.  If it is a little different then it might require 6.4 V or 6.6 V, etc.
Don
DWHIT
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
