Loading...
Pages: [1]   Go Down
Author Topic: IR Sensor and continuous 38kHz signal... not working  (Read 318 times)
Offline Offline
Newbie
View Profile
Hello...
I created a very simple set-up but for some reason I can't get it to work.
I have an IR LED that outputs a continuos 38kHz signal (LED is on and pulsates at 38kHz).
I then have a normal LED hooked up to an IR sensor. Since the sensor receives a continuos 38kHz signal, I would expect this LED
to be on continuously. Unfortunately this is not the case. For some reason it only turns on (flashes) when the sensor receives
a "intermitted" 38kHz signal, as when for example a remote control code is transmitted.
My questions: What might be the issue here, and how can I get the LED to light up continuously in the presence of a continuos 38kHz signal?
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Some IR receivers are designed for continuous duty but most are designed for the pulsing signal of regular IR Remote signals.
Title: Re: continuous ~36kHz IR demodulator receiver
Post by: montyp on September 11, 2011, 06:46:35 AM
i found 2 sensors that can detect continuous IR signals.
they have fixed gain. hope someone would find this useful.
TSOP4038
http://www.vishay.com/docs/81926/tsop4038.pdf
TSOP5803
http://www.vishay.com/docs/81932/tsop5803.pdf
Logged
Offline Offline
Newbie
View Profile
Thanks so much for the info.... Ordered those smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
