Topic: Problems passings strings to function with variable args (Read 2128 times) previous topic - next topic
iisfaq
#include <stdarg.h>
char *P(char *fmt, ... ){
   char tmp[128]; // resulting string limited to 128 chars
   va_list args;
   va_start (args, fmt );
   vsnprintf(tmp, 128, fmt, args);
   va_end (args);
   return tmp;
I am trying to pass a string from an array to this function
String XMLTagStrings[] = {
"data",
"temperature",
"humidity",
"dateTime"
char *data = P("%s",  XMLTagStrings[1]);
Serial.println(data);
I am not sure of the error as it compiles but I get nothing written to the serial port.
If I use the following it works, so I assume that the string below is passed as char *, whereas the other is a String
char *data = P("%s",  "Testing");
I do not know how to translate this so it works with strings - any help appreciated.
Chris
MichaelMeissner
#include <stdarg.h>
va_list args;
va_end (args);
return tmp;
In the future, learn to use code tags (hit the '#' button), it helps people read your code.
Your problem is the tmp declaration is on the stack.  When you return, the stack is erased, and Serial.println will overwrite it.  I would suggest declaring it as:
static char tmp[128]; // resulting string limited to 128 chars
This says to put tmp in static storage which does not change between function invocations.
iisfaq
Good call - I will keep it in mind.
Thanks but it does not fix the issue.
I think it may have something to do with passing a String to the function P
If I pass a constant string "CHRIS" then it works as expected, but if I put "Chris" into a String and pass that the function returns no data and for all I know never returns.
Any other ideas?
Chris
iisfaq
#include <stdarg.h>
   Serial.println("A");
   va_list args;
   Serial.println("B");
   Serial.println("C");
   Serial.println("D");
   va_end (args);
   Serial.println("E");
   delay(100);
   return tmp;
  Serial.println("Starting...");
"data",
"temperature",
"humidity",
"dateTime"
  Serial.println("Before Call");
  delay(100);
char *data = P("%s",  "Chris");
//char *data = P("%s",  XMLTagStrings[1]);
  Serial.println("After Call");
This example shows the issue.
As is it will run but comment out the
and uncomment the
and you will see it never prints "A" inside the P function where it does with the previous call with a static string "Chris"
Hope this helps someone help me.
Chris
MichaelMeissner
Any other ideas?
You can't pass String types to *printf functions.  It does not know about the String type.  Instead you have to convert String back to a char array, and pass that to your function and use %s with it.
iisfaq
After reading this i found that I could simply change my array and it is all happy now
static char *XMLTagStrings[] = {
"xml",
"temperature",
"humidity",
"dateTime"
Thanks
Chris
