Topic: ++ SOLVED ++array label question (Read 960 times) previous topic - next topic
Aug 09, 2012, 11:08 am Last Edit: Aug 10, 2012, 04:46 pm by ArduinoPat Reason: 1
I was wondering if it is possible to label a array of switches ?
For example :
Switch one = LED Red
Switch Two = LED Green
Switch Three = LED Yellow
First i did an easy test with one button , find youtube example:
http://www.youtube.com/watch?v=VU6FR9wvAkM
I was test the sketch in the COOKBOOK , Recipe 2.4 ( Groups and values )
array sketch
an array of switches controls an array of LEDs
see Chapter 5 for more on using switches
see Chapter 7 for information on LEDs
int inputPins[] = {2,3,4,5};  // create an array of pins for switch inputs
int ledPins[] = {10,11,12,13};  // create array of output pins for LEDs
 for(int index = 0; index < 4; index++)
   pinMode(ledPins[index], OUTPUT);         // declare LED as output
   pinMode(inputPins[index], INPUT);        // declare pushbutton as input
   digitalWrite(inputPins[index],HIGH);     // enable pull-up resistors
                                            //(see Recipe 5.2)
void loop(){
   int val = digitalRead(inputPins[index]);  // read input value
   if (val == LOW)                       // check if the switch is pressed
     digitalWrite(ledPins[index], HIGH); // turn LED on if switch is pressed
     digitalWrite(ledPins[index], LOW);      // turn LED off
I understand the working of this code, but how can i  put a name at Ledpins 10,11,12,13 ??
I will show this at the LCD display ,during pushing a switch
Regards,
Patrick
Patrick ,The Netherlands
PaulS
I don't understand the question. You don't have an array of switches. You have an array of pin numbers that switches are connected to. You have an array of pin numbers that LEDs are connected to.
You could easily create two more arrays, containing pointers to strings that have some meaning:
char *switchPinNames[] = {"Red switch", "Green switch", "Blue switch", "Black switch"};
char *ledPinNames[] = {"Red", "Green", "Pink", "Purple"};
Then, use the same index to find a value in all 4 arrays.
byte i = 3;
if(digitalRead(switchPins[i]) == HIGH)
   digitalWrite(ledPins[i], HIGH);
   Serial.print(switchPinNames[i]);
   Serial.print(" is pressed, so the ");
   Serial.print(ledPinNames[i]);
   Serial.println(" LED was turned on");
Thanks for reply PaulS,
Wat you have send is just what i mean ;-)
I have try this sketch but it's not working yet ;-((
What do i wrong:
char *switchPinNames[] = {"Red switch", "Green switch", "Yellow switch"};
char *ledPinNames[] = {"Red", "Green", "Yellow"};
                                             //(see Recipe 5.2)
void loop(){
  byte index  = 4;
   if(digitalRead(inputPins[index]) == HIGH)
   Serial.print(switchPinNames[index]);
   Serial.print(ledPinNames[index]);
When i push the first button ( switch red ) the serial Monitor shows:
green is pressed so , the led  $#$%%^ was turned on
Find attached movie:
http://www.youtube.com/watch?v=BFAevwiYPUI
the other buttons will light up the LED , but it will not show at the serial monitor ???
What i 'am doing wrong with this sketch ??
PaulS
  byte index  = 4;
You are already reading the pin state in the for loop. Why do it again?
You have arrays of size 4, with indices ranging from 0 to 3. You have tried to access the 5th element of several 4 element arrays.
Jimmy60
I'm thinking your sketch needs to look more like this. I moved the bit that outputs into the loop. You had it outside with index set to a value that was out of range for your array.
int inputPins[] = {
int ledPins[] = {
    //(see Recipe 5.2)
void loop(){
The value of index is what points to the desired element in your array.
Dear Jimmy60,
Many thanks for your reply , this is the way i want
It's clear now what i did wrong ,
all works fine now , i have only exchange the follow command:
if(digitalRead(inputPins[index]) == LOW)
in stead of HIGH i put this in LOW ,
In HIGH the LED was ligthing continue , when i exchange this in LOW , I push the button and the LED will on.
Also many thanks to PaulS  :)
http://www.youtube.com/watch?v=1j2CZlD3onw
Best Regards,
Patrick , Maarssen The Netherlands
#6
Aug 10, 2012, 11:07 am Last Edit: Aug 10, 2012, 04:46 pm by ArduinoPat Reason: 1
Dear All,
all works well , but now i have adjust this sketch to an I2C LCD,
All works fine but after pushing the last button action , the text shows at the LCD and will not clear.
So when i push the Yellow button , the LCD display continue show Yellow pressed.
I have try it with lcd.clear at the end of this sketch , but then the LCD will continue empty , also during pushing the buttons ????
http://www.youtube.com/watch?v=mHO_VeuHI20
 "Red ", "Green", "Yellow"};
int inputPins[] = {
int ledPins[] = {
// I2C LCD
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
lcd.init();                      // initialize the lcd
 // Print a message to the LCD.
 lcd.backlight();
   //(see Recipe 5.2)
void loop(){
     lcd.setCursor(0, 0);
     lcd.print(ledPinNames[index]);
     lcd.print(" Pressed,   ");
     lcd.clear();  //this will not work !!!! LCD keeps empty !!!
Regards,
Patrick , ArduinoPat , The Netherlands.
#7
Aug 10, 2012, 04:49 pm Last Edit: Aug 10, 2012, 09:25 pm by ArduinoPat Reason: 1
All works well now !!
all i had to do is the follow line:
lcd.print("                            ");
that was all  :smiley-fat:
Find attached the correct working sketch:
int inputPins[] = {
int ledPins[] = {
// I2C LCD
#include <Wire.h>
   lcd.init();
   lcd.backlight();
    //(see Recipe 5.2)
void loop(){
      lcd.print("                ");
Best Regards , ArduinoPat , The Netherlands
