Topic: 5v down to 3.3v for 3.3v sensitive devices (Read 924 times) previous topic - next topic
iisfaq
Just a simple question
If I  am using a 5v arduino and my sensor or device requires 3.3v for power + data lines what is the best way to do this?
Should one just use a voltage divisor with 2 resisters?
Should one use a 3.3v regulator for the power + 2 resisters for the data lines?
Should one use a 3.3 volt regulator for eveything?
Is there something else you should use?
I am just wondering as I have really only used the 3.3v line from Arduino + 2 resisters but is that a good method? Doesn't this waste energy as heat? Especially when running from battery power?
Chris
wanderson
You need a regulator for 3.3v, but the Arduino's usually provide that.  You can get by with a resistor divider for data lines in some cases, but a level converter is a better general choice.
New true random number library available at: http://code.google.com/p/avr-hardware-random-number-generation/
Current version 1.0.1
iisfaq
Thanks for the advise, do you have a recommendation on a particular device?
I will do some searches myself now so I can get familar.
Cheers
Chris
wanderson
This is a little expensive, but it is a good general purpose converter with eight channels; http://www.adafruit.com/category/products/395
There are many other options though.
jointtech
I use this but it looks like they are out of stock.
https://www.sparkfun.com/products/8745
florinc
Only 50mA, may be enough for an SD card, but not enough for an XBee (for example).
JoeN
I did one little breadboard project with a 3.3V GPS device, the only 3.3V device I have interfaced so far.  I did it with an ATMega328P so I didn't have 3.3V from an Arduino.
As for power, I used this regulator which seems to have a good reputation, works fine, multimeter says it is spot on:
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_897188_-1
Now the nice thing is that the GPS could be interfaced to the INPUTs of the ATMega328P fine - 3.3V drives the inputs without any trouble, and the GPS itself needs no input, it starts sending data once it has it.  So I was set there.
If you need to send output to a 3.3V device you need to use a level converter like the one mentioned above which seems to be bidirectional and intelligent and out of stock.  As an alternate, there is this not quite as elegant solution:
But it is now out of stock too.  What gives with all these level converters out of stock?
I have only come here seeking knowledge. Things they would not teach me of in college.
Jack Christensen
#8
Aug 10, 2012, 02:19 am Last Edit: Aug 10, 2012, 02:35 am by Jack Christensen Reason: 1
Sometimes the better choice can be to run the whole system on 3.3V. Depends on the sensors and other devices involved.
When running on batteries, an Arduino is often not a great choice. For example, an Uno board will consume 3-4 times the current/power of just the ATmega328P microcontroller alone. That is a not criticism; after all, it is a development board, and that is the price paid for the convenience it provides. While the 328P can be put to sleep, and that is a great option for battery-powered applications, certain components on the Arduino board continue to draw power regardless. I would strongly consider a custom circuit design for a battery-powered application.
MCP79411/12 RTC ... "One Million Ohms" ATtiny kit ... available at http://www.tindie.com/stores/JChristensen/
