Offline
Newbie
« on: August 09, 2012, 04:13:01 pm » |
Hello ppl. I found this site: https://sites.google.com/site/carlosoliveiraprojects/home/arduino/gsm-and-arduinothis guy can make the arduino send an sms to the mobile phone number as you can see on the site. I wonder if you can do the opposite, I want to send a message from my phone to the arduino to trigger a relay. Is it possible? somebody help me with the code?
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #1 on: August 09, 2012, 05:01:17 pm » |
He doesn't need a GSM Shield because he uses an entire GSM cellphone: GSM Siemens C75 phone. Is that what you want to use for receiving SMS messages?
Logged
Offline
Newbie
« Reply #3 on: August 11, 2012, 04:40:01 pm » |
you would probably need some sort of communications interface. If you have a land line you can setup an SMS gateway on a computer. Have the computer parse the SMS message and send it to the arduino via serial. Alternatively, you could use an Ethernet shield, and either have the original computer parse the SMS message from the gateway and send it via Ethernet to the arduino. Or if you are feeling up to it you could write your own sms gateway interpreter that runs solely on the arduino that has wi-fi, ethernet capability.
There are some free implementations of SMS gateways available on linux. I'm not to sure about windoze.
Logged
Offline
Newbie
« Reply #4 on: August 22, 2012, 11:48:28 pm » |
I was thinking about doing the exact same thing with an old but indestructible Nokia 5070 phone. I have already ordered a $1.25 fbus cable. I think that a serial converter needs to be used (max-232) and then part of the problem is that programming trunks is not that easy... but where is the fun if you take that out? I want to make a simple alarm watching a door with a hall effect magnetic sensor and also use a classical IR sensor. Also, I plan to user the nokia battery to power the whole thing, and the original nokia charger. This alarm will be totally silent. If there is a break in, only an SMS will be sent to my phone and maybe to my mother's.
Also I was thinking that it should be possible to make arduino answer an incoming phone call, if you want to listen to whatever is going on at your place.
As I live in Argentina, most GSM shields will not work here (must be 4 bands or at least have the 850 Mhz band)... the ones available are way too expensive. This experiment will cost me close to nothing. The phone has been lying around for years... the rest of the parts I already have.
The beauty of this is that you can do a lot of things. I want a custom alarm, just because I cannot think of another use, but if you live in the country side and you want to control remotely things that are really far away, like water pumps or some other stuff, this can be an option.
There is a lot of info about Nokia trunk programming in the web. I can post advances when my cable arrives and I start playing with this.
Logged
Offline
Newbie
« Reply #5 on: December 05, 2012, 10:02:04 am » |
Hi, i'm interesed to control few relays via Arduino and GSM phone. Some old phones we can bought much chiper than any specialized modem or shield. It will be nice to get nokia 6300 or similar to work via USB interface. Anyone did some trys?
Logged
Offline
Newbie
« Reply #6 on: December 05, 2012, 11:29:27 am » |
I got stuck with this project as the SMS frame for Nokia 5070 is not published and even gnokii will not know how to handle it.
I was thinking about downloading the nokia suite, log the com port and try to figure out the frame differences, but I have not had the time to do so...
On the other hand, if the phone is supported by gnokii, it is possible to make it work.
I did develop a library of c functions to set up the frame, including the generation of checksums and 7 bit coding.
Regards
Logged
Offline
Newbie
« Reply #7 on: December 05, 2012, 01:37:48 pm » |
If you can sniff and analyze phone-pc communication, you can install Mobiledit with c.r.a.c.k, It allow to read SMS data and it is done via USB. So that can be better for future.
Logged
Offline
Newbie
« Reply #8 on: January 06, 2013, 11:07:51 am » |
I know Nokia 5070 has Symbian S40 ver2, so you can do your project with AT commands (like AT+CMGR... ).
Logged
Offline
Full Member
« Reply #9 on: January 09, 2013, 12:18:44 am » |
Look into my new site power7.net for sms remote control with cellphone and the photo page inside the site.
« Last Edit: January 09, 2013, 01:42:34 am by antkan »
Logged
