Topic: Change the Default sketch (Read 4322 times) previous topic - next topic
eried
XD I changed the default sketch and published it as a mod:
http://arduino.cc/forum/index.php/topic,118440.0.html
My website: http://ried.cl
Tom Carpenter
Is it just a modified class file like before? If so could you just post that class file as I don't need all the other stuff and this 50MB download is taking forever (its not my internet access as usually I get about 20Mb/s)
~Tom~
eried
Yes but I don't remember 100% if is only this file, this time was harder to add via 'hack', I used an old string I found inside the class (something about "Sunshine- go to take a walk", when the sketches of the day are more than N number hahah). (Attached)
Tom Carpenter
Thanks, that worked great. Just renamed pde.jar in the /lib/ folder to a zip, replaced the class file, and renamed it back. Worked a treat!
~Tom~
Tom Carpenter
#19
Aug 14, 2012, 12:34 am Last Edit: Aug 14, 2012, 12:37 am by Tom Carpenter Reason: 1
I modified that class a tiny bit - I just replaced a couple of the characters in the default sketch for the same amount of different ones, so that it is now this:
 // This code will only run once, after each powerup or reset of board
 // This code loops consecutively
Having the new lines is helpful. Yeah I know, I am too lazy to just press Enter, LOL!
I think I can live without the weird string about taking a walk!
~Tom~
eried
Cool, you can edit the template with an hex editor :)
eried
:D hehe Walk needed after 26 sketches per day
Tom Carpenter
Perhaps. But in windows 7, you don't even need to extract the zip, you can just copy the new file directly into the zip folder, so it is just as easy.
~Tom~
