Loading...
Pages: [1]   Go Down
Author Topic: Problems with Arduino Mega 2560 on Windows Vista-64  (Read 212 times)
Offline Offline
Newbie
View Profile
I am using a Arduino Mega 2560 Board connected to a Windows Vista-64 computer. Everything says it downloaded and installed correctly. When I connect the USB cable there is a Red LED that comes on. It is located just above the reset switch (Button). The L, TX & RX LED's do not light up or blink. When trying to upload the file "Blink", to test the system, I get. what appears to be a freeze in the upload process. A bright flash comes from the red L LED followed by a dim steady light from this LED. The green RX LED blinks about every 10 seconds. The upload never appears to become complete. Any Ideas?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Are there any messages in the IDE?
Enable the verbose upload option in preferences, and see if that tells you anything.
Logged
Offline Offline
Newbie
View Profile
Binary sketch size: 1,632 bytes (of a 258,048 byte maximum)
C:\Users\**\**\arduino-1.0.1-windows\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CC:\Users\**\**\arduino-1.0.1-windows\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\**~1\AppData\Local\Temp\build8774323326409129864.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Users\**\**\arduino-1.0.1-windows\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM4
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_getsync(): timeout communicating with programmer
         AVR Part                      : ATMEGA2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: Unknown
avrdude: Send: . [1b] . [01] . [00] . [02] . [0e] . [03] . [90] . [85]
Logged
Offline Offline
Newbie
View Profile
Does the verbose printout tell you anything? I see it has timed out getting a message back. The question is why?
Logged
Pages: [1]   Go Up
Print
Jump to:
