Loading...
Pages: [1]   Go Down
Author Topic: One LED indicator for every GPIO pin.  (Read 623 times)
Offline Offline
Newbie
View Profile
Since we have so much more space in the arduino due to the switch to SMDs, and better wiring layout...
Would it be possible to attach a LED to every pin? I understand the problem of current draw, but try adding a IC with multiple mosfets on it. If I remember MOSFETs have huge Gate impedance, so there should be minimal to zero current draw by the mosfet switches.
If having one led for every GPIO pin is too much, then use rgb leds, so you have cover 3 pins at a time with one LED packaging.
In the future, it would be even better if we can have a simple indicator using small strips of eink (those 'bar' types you see in lexar flashdrives with capacity display), if I also remember for eink, they are very simple to drive directly.
Logged
USA
Offline Offline
God Member
View Profile
Beyond the addtional current (which I think will still be more appreciable than you realize), there is the fact that adding LEDs will increase the total cost to make the official boards.  Even though the LEDs aren't the most expensive electronic component, especially in bulk, there would still be at least a dozen more on the Uno or Leonardo boards (the Analog pins can also function as digital I/O pins), and at least a few dozen for the Mega.  That's going to lead to something like an increase of 1 to 2 USD/Euro, at minimum, for a feature that isn't going to be used a majority of the time.
Now there's nothing to stop someone from producing a variant Arduino board with LEDs on each pin, but I don't think it makes sense to make this addition the official boards.
Logged
Offline Offline
Newbie
View Profile
I see about the cost now. Fair enough.
I don't know how you think it won't be used. I see it more of a 'feedback' debug mechanism, which would help in debugging, or just letting you visually identify any problems.
Perhaps we don't need it for every pin. Still I think we can do with more than one led on pin 13. How about one RGB led, like in the leostick? Good compromise?
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
No.
How about built your own visual debugger as a stand alone device, you can then use it in as many projects as you like without having to pay for LEDs every time.
If there was enough demand for something like this someone would already be selling such a sheild, I assume noone is and that therefore there are not enough people that want this.
Duane B
Logged
Offline Offline
Newbie
View Profile
In terms of the No, I hoped you read the entirety of the last post, which had one modification to the idea to consider.
Do you also reject the "single RGB led output" like the freetronic LeoStick?
The above modified proposal has the same look at the original, except the pin13 led has been replaced with a RGB version.
Logged
Grand Blanc, MI, USA
Offline Offline
Edison Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
Google up Udo Klein's Blinkenlight Shield. Not sure right off what resistor value he uses, but I've recently been playing with some surface-mount LEDs, I'm using 1K dropping resistors, so only drawing about 3mA per LED, and they are impressively bright with a 5V MCU. Even at 3.3V they are very much usable as indicators.
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Pages: [1]   Go Up
Print
Jump to:
