Topic: Video camera with arduino + image processing. (Read 68036 times) previous topic - next topic
Shploop
Hi, I want to connect a color video camera to my Arduino and process the data I get (Object recognition by color and such). I know the Arduino is not powerful enough to handle complex image processing but I only need simple processing. I am also looking for a cheap video camera(up to 40$) that I can hook up to the Arduino.
The camera doesn't need high resolution or high image quality just to capture video and preferably digital so I won't have to add a circuit to translate analog signals to digital.
if you have experience with an Arduino+camera and image processing using the arduino(not a pc) I would like to hear about it.
Sandeep_Raj
http://embeddedeye.com/profiles/blogs/turn-your-arduino-into-an
Grumpy_Mike
Quote
Well that add on board does:-
Quote
the Tam4 at 4x32 pixels.
So it is not very high resolution.
Quote
The truth is you can't do any sort of image processing at any sort of quarter decent resolution on an arduino without having a ton of extra stuff bolted on.
Shploop
these resolutions are very small and if you say I need to give up image processing on the Arduino, can you recommend a relatively cheap processor for this task?(my first thought is raspberry pi)
Grumpy_Mike
Yes potentially a Raspberry Pi could do it, but it is still a bit of a work in progress at the moment. It is planned to have a camera board specially designed for it, but it is not ready yet.
cr0sh
Things to consider (may not be up to your needs or requirements):
http://nootropicdesign.com/ve/
...also:
http://www.jrobot.net/Projects/AVRcam.html
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
-SaRaH-
I know exactly what you need. If you already have a Android Phone. Get this https://www.sparkfun.com/products/10748
and your project is half done.
dxw00d
A Beaglebone might be the answer. It is, apparently, capable of running OpenCV.
http://beagleboard.org/bone/
Shploop
That IOIO for android is nice but I need my project to be standalone not related to my phone.
I am checking out beagleboard to see if it will fit my needs.
esdad697
Might you give some idea what your application is? It would expand the discussion.
Shploop
Just object recognition by color(red) I need to recognize one or a number of stationary round objects(not perfectly round) in my camera's frame. The camera will be mounted on a robot that will walk and recognize these round objects in his environment.
zoomkat
Natures warning sign: if it were easy, you would already see thousands of similar projects. If you don't see them, there is probably a reason.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
esdad697
Use a smartphone. If you don't have one, ask friends and family for an old one. It does not require phone call capability which is why an old phone is ideal. Smartphones support openCV which you could then play with for hours. I'd also recommend you send the images to a PC for R&D. It is a better practice to work with image processing on a PC with OpenCV, Octave or MatLab. Once you figure out what you are doing, then recode it on a smartphone. OpenCv on a PC is better is because it is funner. You are more likely to get it working and have fun doing it.
Shploop
#13
Aug 18, 2012, 06:35 am Last Edit: Aug 18, 2012, 06:38 am by Shploop Reason: 1
That won't help me I need the robot to be microprocessor based not smartphone based and I need it to work without the aid of a PC. Simple object recognition can be done with analyzing the color of each pixel in a frame's scanline and going through all the scanlines in a frame, I don't need high fps and can lower the frames I actually process to 10 or even 5 in a 30 fps camera, this combined with a not so high resolution will enable me to create this robot.
I know I sound like I am trying to build Rome( :P ) but with some thinking I can make this project work, I am sure someone did something similar before.
zoomkat - So if it turns out it wasn't done before so what? I'll try it, this is far from impossible.
Sandeep_Raj
You already have all your options listed. You will have to choose one of those.
Or, simply get a color sensor http://www.sunrom.com/sensors/color/color-sensor . It recognizes the color, but not the object. The rest depends on your coding.
