Pages: 1 [2]   Go Down
Author Topic: An error...  (Read 406 times)
Gosport, UK
This compiles:
//Remote Vehicle Ignition
//State Machine begin
#include <SoftwareSerial.h>
char inchar;
SoftwareSerial cell(2,3);
// system states
#define STOPPED   0
#define STARTING  1
#define CRANKING  2
#define RUNNING   3
#define FUEL_PUMP_PRIME_TIME  5000
#define RUNNING_TIMEOUT 60000UL
const int ignitionPin = 12;
const int onPin = 11;
const int ledPin = 13;
const int onledPin = 9;
const int alternatorPin = 4;
int state = STOPPED;        // master variable for the state machine
unsigned long StartingTime; // fuel pump priming
unsigned long RunningTime;  //  ten minute timeout
  pinMode(onPin, OUTPUT);
  pinMode(onledPin, OUTPUT);
  pinMode(ignitionPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(alternatorPin,INPUT);
  Stop();
  cell.begin(9600);
  delay(30000);
  cell.println("AT+CMGF=1");
  delay(200);
  cell.println("AT+CNMI=3,3,0,0");
  delay(200);
  switch(state)
  case STOPPED:
    HandleStoppedState();
    break;
  case STARTING:
    HandleStartingState();
    break;
  case CRANKING:
    HandleCrankingState();
    break;
  case RUNNING:
    if(millis()-RunningTime > RUNNING_TIMEOUT)
      Serial.println("Running Timeout");
      Stop();
    break;
  default:
    Serial.print("Unknown State: ");
    Serial.println(state);
    Stop();
    break;
void Stop()
  Serial.println("TimeOut");
  digitalWrite(ignitionPin,LOW);
  digitalWrite(onPin,LOW);
  digitalWrite(onledPin,LOW);
  state=STOPPED;
void HandleStartingState()
  if(millis()-StartingTime > FUEL_PUMP_PRIME_TIME)
    if(digitalRead(alternatorPin)==HIGH)
      Serial.println("Abort cranking");
      Stop();
      Serial.println("Starting Vehicle");
      digitalWrite(onPin,HIGH);
      digitalWrite(ignitionPin,HIGH);
      state=CRANKING;
void HandleStoppedState()
  if(cell.available() >0)
    inchar=cell.read();
    if (inchar=='#')
      delay(10);
      inchar=cell.read();
      if (inchar=='s')
        delay(10);
        inchar=cell.read();
        if (inchar=='0')
        else if (inchar=='1')
          Serial.println("Priming Fuel Pump");
          StartingTime=millis();
          state=STARTING;
void HandleCrankingState()
    Serial.println("Vehicle Running");
    digitalWrite(onledPin,HIGH);
    RunningTime=millis();
    state=RUNNING;
But I don't have your hardware, so I don't know if it works.
Seaford, Victoria, Australia
This compiles:
char inchar;
// system states
#define STOPPED   0
#define STARTING  1
#define CRANKING  2
#define RUNNING   3
  Stop();
  cell.begin(9600);
  delay(30000);
  delay(200);
  delay(200);
  switch(state)
  case STOPPED:
    break;
  case STARTING:
    break;
  case CRANKING:
    break;
  case RUNNING:
      Stop();
    break;
  default:
    Stop();
    break;
void Stop()
  state=STOPPED;
      Stop();
      state=CRANKING;
    inchar=cell.read();
    if (inchar=='#')
      delay(10);
      inchar=cell.read();
      if (inchar=='s')
        delay(10);
        inchar=cell.read();
        if (inchar=='0')
          state=STARTING;
    state=RUNNING;
Thanks! shall test shortly.
But why are there so many braces at the end?
UK
Yes, paying attention to indentation and matching braces as you go along will pay dividends.
Seattle, WA USA
Seattle, WA USA
As soon as i add this, it fails.
We're only going to tell you about 14 more times. You absolutely MUST have EXACTLY ONE { for every }. That last block of code has 9 curly braces - some open, some close. It must have an even number. Period. You can try anything you like but you can NOT get around that fact.
Thank you Paul for the sarcastic reply.
I'm fairly sure i now understand.
Regards.
Melbourne, Australia
Shannon Member
Lua rocks!
You can reduce the number of braces by reversing the logic, to a certain extent, eg. instead of:
    state=RUNNING;
You can do this:
  if(digitalRead(alternatorPin)==LOW)
    return;
  state=RUNNING;
Now you don't have as many nested braces.
A good rule of thumb when coding is to always write the closing brace as you write the opening one. Eg. writing your original code:
   <---- write the closing brace and up-arrow to here to write the function
}  // end of HandleCrankingState
The comment says why the brace is there.
Then:
      <---- write the closing brace and up-arrow to inside the "if"
  }  // if alternatorPin is HIGH
Get into the habit of doing that and these problems will go away.
NYC
The singularity is near!
You fixed it, nice job!
Well, no i didn't fix it, you kind people did.
And along the way, i learnt some good lessons, cheers everyone!
It compiles, uploads and works perfect.
Pages: 1 [2]   Go Up
