Topic: Simple WiiRemote Bluetooth Robot (Read 2414 times) previous topic - next topic
rameses32
Here is a video of it so far. http://www.youtube.com/watch?v=LZ-nfHzsGeM
It's an extremely simple platform, just 2 modified nine gram servos I got from Ebay for $2.50 each and a $2 Bluetooth Dongle.
Charley
Here is the Sketch
Quote
#include <WiiRemote.h>
#include <Servo.h>
#define STEERING_ANGLE_MAX    160
#define STEERING_ANGLE_MIN    20
#define STEERING_ANGLE_CENTER 90
#define STEERING_ANGLE_STEP   5
Servo Left_servo;  // create servo object to control a servo
Servo Right_servo;
int deg1;
int a;
WiiRemote wiiremote;
  wiiremote.init();
  Left_servo.attach(6);  // attaches the servo on pin 3 & 6 to the servo objects
  Right_servo.attach(3);
void loop(){
  wiiremote.task(&myapp);
void myapp(void) {
    int steering_angle = getSteeringAngle();
int getSteeringAngle(void) {
  double rad; // y accel setup
  double deg; // y accel setup
  double rad2; // X accel setup
  double deg2; // X accel setup
  rad = acos((double) wiiremote.Report.Accel.Y);
  deg = rad * 180.0 / PI;
  rad2 = acos((double) wiiremote.Report.Accel.X);
  deg2 = rad2 * 180.0 / PI;
  /* clipping */
  if (deg2 > STEERING_ANGLE_MAX) { deg2 = STEERING_ANGLE_MAX; }
  else if (deg2 < STEERING_ANGLE_MIN) { deg2 = STEERING_ANGLE_MIN; }
  if (deg > STEERING_ANGLE_MAX) { deg = STEERING_ANGLE_MAX; }
  else if (deg < STEERING_ANGLE_MIN) { deg = STEERING_ANGLE_MIN; }
if (deg2 >= 85 && deg2 <= 95) { Left_servo.detach(); //eliminates drift at servo center position
Right_servo.detach(); }
if (deg2 > 90) { a = deg2 - 90; //Inverts output to reverse right servo
deg1 = 90 - a;
else if (deg2 < 90) {a = 90 - deg2;
deg1 = 90 + a;
if (deg >= 80 && deg <= 100) {
   Left_servo.write(deg2);
   Right_servo.write(deg1);
else if (deg < 80) {
  Left_servo.write(90);
else if (deg > 100) {
  Right_servo.write(90);
