@gooby:
If tomorrow somebody comes to you and asks you following:
"I need to connect this nice blue LED to this 1300V voltage source to indicate it is on", you will calculate it simply:
- this blue LED lits nice at 4mA current (you know that from your experience)
- typical forward voltage for blue LED is 3.5Volt (you google that)
R = ( 1300V - 3.5V ) / 0.004A = 324000ohm (you will use 330kohm)
Power at resistor = I*I*R = 0.004A * 0.004A * 330000ohm = 5.28 Watt (you will use 10Watt resistor to keep it cooler)
Power at LED = U * I = 3.5V * 0.004A = 14 mWatt
So you need a 330kiloohm 10Watt rated resistor to be happy (mind the high voltage is lethal !)
