Topic: Servo uncontrollable (Read 2368 times) previous topic - next topic
akkkk
Hi, I've been trying to control a HD-1440A microservo for a while now (http://www.pololu.com/file/0J319/HD-1440A.pdf). I have quite a lot of these, so I'm guessing they are not all defective, although I originally felt I may have been doing something to make them defective.
I'm using the default servo sweep script:
Code: [Select]
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
and this is how I've connected everything together:
They do 6 full 360 degree turns, before turning 180 degrees the other way. This just repeats. I've included a diagram of my circuit. I'm guessing since the servo has a yellow, red and brown wire, that brown is the negative.
Does anyone know why this is happening? Thanks!
AWOL
Quote
What sort of servo is that?
The PDF you linked says they have a 180 degree limit.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
akkkk
Quote
A broken servo, or a servo that's wired up wrong.
This is the problem I am having.
AWOL
No, really, most servos have mechanical stops that will physically damage them if you try hard enough to rotate them past 180 degrees.
This isn't one of those continuous-rotation ex-servos, is it?
akkkk
These were all new servos, and I haven't done anything to them, the first servo I ever had stopped working when I forced it round, so I know not to do that.
So if it's wired up correctly I really don't know what is wrong with them. But it's odd that they would all behave this way.
AWOL
Quote
Time to double-check your wiring.
akkkk
Quote
Is the wiring in the diagram correct?
AWOL
I don't know - I can't read those Fritzing things,
retrolefty
Quote
That sounds like you have a servo that has been modified for continuous rotation. Unmodified servos are unable to travel more then around 180 degrees maximum. That means it is no longer a servo but rather like a simple bi-direction variable speed geared motor. As such you need to rethink what your servo commands will actual have the 'servo' do. You no longer have any means to precisely control where it will stop.
Lefty
Krodal
Can you make a fresh start, and use only standard normal things ?
Use 5V for the Servo. You could use the 5V of the Arduino, but the voltage regulator could get hot. Don't use the USB power for that, but use an adapter.
The connector is - + s    ('s' is signal/data). I think you have it wired okay.
Don't use that example code, go for example to 0 degrees, wait 5 seconds, go to 180 degrees, wait 5 seconds, and so on. If they keep on turning they are modified.
What do you call 360 degrees, you could stick red tape to one of the legs.
Did you buy them new in a shop. If so, they are unmodified for sure. Are they used, then they could be modified.
zoomkat
You need to find out what kind of servo you have. Also your battery shows 3.7v, but normal "standard" servos have a minimum operating spec of 4.8v. Make sure the servo, arduino, and battery grounds aer actually connected together. Below is some simple servo test code for use with the serial momitor.
Code: [Select]
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
    readString=""; //empty for next input
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
