Hi, I've been trying to control a HD-1440A microservo for a while now (
http://www.pololu.com/file/0J319/HD-1440A.pdf). I have quite a lot of these, so I'm guessing they are not all defective, although I originally felt I may have been doing something to make them defective.
I'm using the default servo sweep script:
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
and this is how I've connected everything together:
They do 6 full 360 degree turns, before turning 180 degrees the other way. This just repeats. I've included a diagram of my circuit. I'm guessing since the servo has a yellow, red and brown wire, that brown is the negative.
Does anyone know why this is happening? Thanks!
