Topic: LED RGB 64-control individually (Read 23309 times) previous topic - next topic
Grumpy_Mike
Code: [Select]
// Set the first variable to the NUMBER of pixels. 25 = 25 pixels in a row
Adafruit_WS2801 strip = Adafruit_WS2801(6, dataPin, clockPin);
You have the LED connected to pin 8 but your software says there are only 6 pixels, so try putting 18 here.
Omnimusha
Grumpy_Mike
Grumpy_Mike
Make sure you have wired it up correctly with all three anodes going to the +ve and each cathode going to a seprate output pin.
Omnimusha
You said, you connect as pictured below?
KirAsh4
You have your SDI and CLK pins reversed.  Pin 13 on the Uno is the clock, not data.  Pin 11 is MOSI (data).
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
