Loading...
Pages: 1 ... 8 9 [10] 11 12 ... 33   Go Down
Author Topic: [MOD] Arduino Enhanced Release 1.0.5 for Windows (installer, drivers, etc) +SRC  (Read 99537 times)
0 Members and 3 Guests are viewing this topic.
Offline Offline
Sr. Member
View Profile
+1 for individual character undo, and maybe have a prefs setting to set a limit if people want that function.
Logged
Chile
Online Online
Edison Member
Arduino rocks
View Profile
WWW
OK, I think 10000 is a small "buffer" since the only combined stuff arduino does is the indentation (as a block) so teorically 100 tabs with 10000 undos will use less than 1 mb of ram (considering only the char data).
I am believing I need to add some easy updater so the app is automatically updated (only the changed components) because I will still not upload the new installer only for the undo cache, but I will change the font and try to fix other stuff before releasing an update this week.
Logged
My homepage/blog: http://erwin.ried.cl
Hitchin, UK
Offline Offline
Newbie
View Profile
I like the update.
Is there anyway to improve the highlight error display. Currently the package highlights the line where it thinks the error is, however I am not sure that it is taking into account any comments because it always highlights a line earlier in the buffer than were the error is.
Logged
Chile
Online Online
Edison Member
Arduino rocks
View Profile
WWW
I like the update.
Sure thing, I also noticed that but I am not 100% sure what's wrong.
If you can come up with some samples of the error and some guesses about what is wrong (what is and what isn't accounting for the line alignment), I can for sure enhance that for some next version.
Logged
Offline Offline
Sr. Member
View Profile
Open example ASCIITABLE, delete the ";" at line
Code:
 // prints title with ending line break
  Serial.println("ASCII Table ~ Character Map");
The line
Code:
The circuit:  No external hardware needed.
is highlighted.
EDIT: For next update, I`d like an option to (auto?) open the last sketch I was working on.
Thanks!
« Last Edit: October 16, 2012, 04:27:54 am by Lakes » Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Interesting. In my standard 1.0.1 IDE, the correct line is highlighted.
Logged
Chile
Online Online
Edison Member
Arduino rocks
View Profile
WWW
Right, but I am pretty sure it fails in other cases I remember somebody asking about this, anyway it is a different compiler. It is only the comments, is easy to fix.
Logged
Chile
Online Online
Edison Member
Arduino rocks
View Profile
WWW
Update 2012-10-19:
I used another font now smiley to support accents
Also undo buffer is now 10000
Enjoy!
Logged
Offline Offline
Sr. Member
View Profile
Very good, but that comments bug is still there...
Logged
Offline Offline
Newbie
View Profile
I've noticed some strange behavior in tab navigating.  When I first open the ide and use the keyboard shortcur (CNTRL + ALT + Arrow) for moving between tabs, if jumps two tabs at a time (either direction you choose).
If I then go to the tab menu and select either next or previous tab from the menu, the keyboard shortcuts start working correctly and only move one tab at a time.
This behavior repeats every time I open the ide.  Also, I checked the official ide and it works correctly and does not do this.
Logged
Offline Offline
Newbie
View Profile
Personnaly, I'd like to request that the font stop changing.  Pick one and stick with it.  One way to fix this would be to add a drop down for font choice in the preferences tab.  If font choice was easy to change, people would be less enclined to complain and request changes.
Now that I've ranted a little, I'd like to compliment you on how much great stuff you've done with this.  Just sent you a donation.
Logged
Offline Offline
Sr. Member
View Profile
I don`t mind the new font, but have made it 14 point, so its easier to see where any "{ }" or ";" are missing. smiley
It would be nice to have them different colours, or maybe in bold font style, someway of making them standout anyway.
EDIT: noticed something else, I don`t get the "not in sync" error when switching between UNO and Duemilanove w/328p boards.
« Last Edit: October 20, 2012, 10:07:09 am by Lakes » Logged
Chile
Online Online
Edison Member
Arduino rocks
View Profile
WWW
Wow, I have to check that!
Thanks for the donation! About the font, I noticed the problem with the accents, so I just looked for a new one that supported everything. A font option is good idea anyway.
What bug?
Logged
Offline Offline
Sr. Member
View Profile
The one where it highlights the wrong line for an error.
Open the ASCIITable example, delete the ';' at   Serial.println("ASCII Table ~ Character Map");
See the comments line  " The circuit:  No external hardware needed."  at the top highlighted.
If you delete the comments, then the correct line is highlighted.
Logged
Chile
Online Online
Edison Member
Arduino rocks
View Profile
WWW
Ohh, yes sorry. I make some patches every couple days and when something seems "important" I make a setup file and publish them. I was playing with an script and noticed the problem with the old font so decided to release the pending changes.
But not worry eventually I have to tackle down all the issues.
Right now, problems in order or priority:
1) Check the tab switch thing
2) Error line+comments
3) Font selector
4) Win8 x64 drivers
« Last Edit: October 20, 2012, 11:48:17 am by eried » Logged
Pages: 1 ... 8 9 [10] 11 12 ... 33   Go Up
Print
Jump to:
