Topic: [MOD] Arduino Enhanced Release 1.0.5 for Windows (installer, drivers, etc) +SRC (Read 460950 times) previous topic - next topic
Lakes
mattallen37
I've installed WinAVR for programming raw AVRs. I used it for a while, and it worked great. Just recently I attempted to use it again, and it tries to use the AVR tools located in C:\Program Files (x86)\Arduino\Arduino ERW 1.0.1i\hardware\tools\avr\bin instead of C:\WinAVR-20100110\bin. In doing so, it seems to have broken something, and the WinAVR stuff no longer works properly (things such as "Make All", and "Program"). There shouldn't be any connection what-so-ever between WinAVR and Arduino ERW 1.0.1i. The only thing I could think of is that the computer register system got messed up somehow, so that it looks in the wrong directory. I went to the Registery Editor, location "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment" key "Path", and it does indeed include reference to C:\WinAVR-20100110\bin as well as C:\Program Files (x86)\Arduino\Arduino ERW 1.0.1i\hardware\tools\avr\bin. Something interesting to note, is that it includes no reference to the original Arduino IDE's tools, which are in directory C:\Program Files (x86)\arduino-1.0.1\hardware\tools\avr\bin.
I don't know exactly when/where the problem started. WinAVR was working fine along side of the official Arduino IDE, but I hadn't tried using WinAVR since I installed this enhanced Arduino IDE.
If in the registry key I remove the reference to the Enhanced Arduino IDE and I rename the program folder "Arduino ERW 1.0.1i" to e.g. "__Arduino ERW 1.0.1i", then I can use WinAVR. However, I need to "Make All" twice in order for most of it to succeed (still has an error, something to do with the EEPROM).
Perhaps you can shed some light on this situation.
What all registries does the Enhanced Arduino IDE use?
Can you think of any good solution?
UPDATE: Through some more investigating, it seems that the Enhanced Arduino IDE started using that specific registry key in version 1.0.1c (it didn't seem to in 1.0.1b). It also seems that renaming the program file for the enhanced arduino IDE is all that's needed (to get to the point I'm at now); it doesn't seem that that specific registry key is the (sole?) cause.
eried
The IDE does not need anything, but new WinAVR needs a PATH entry to work properly.
I created an 'Environment variable manager' application that handles this and it is called by the setup (line 113):
https://github.com/eried/Arduino/blob/4e2a003da583bee73b487825d2932cdb90203e15/erw/setup.iss
So if you can change the path, just type this in the command prompt:
Code: [Select]
"C:\Program Files (x86)\Arduino\Arduino ERW 1.0.1i\erw\SetPath.exe" -a "<your winavr path>" -r hardware\tools\avr\bin
Code for SetPath is https://github.com/eried/Arduino/blob/master/erw/csharp/SetPath/Program.cs
I tried to keep everything clean, but if you install WinAVR before my mod, I will have to append the WinAVR path anyway to keep the IDE working
My website: http://ried.cl
mattallen37
I'm not entirely sure what I'm supposed to do to fix the problem.
I ran the command prompt line you posted (after filling in the WinAVR bin location). It seems to have removed the directory "C:\Program Files (x86)\Arduino\Arduino ERW 1.0.1i\hardware\tools\avr\bin" from that registry key I mentioned earlier, but it doesn't seem to help any more than me manually removing it.
eried
Right, but I am not sure what is your problem really. You have a newer version of WinAVR? because having the path for C:\Program Files (x86)\Arduino\Arduino ERW... set means you can use WinAVR from any command prompt without having to install it again.
mattallen37
I have WinAVR-20100110, and I don't run it from a command prompt (well, rarely I run avrdude from it). I use Programmer's Notepad, which is included with WinAVR, and i use the "Make All" and "Program" "buttons" in the Tools menu of pn.
eried
Well, since winavr requires the environment variable, one option is to keep only one, from arduino and set that path from Programmer's Notepad?
I was not able to make the compiler to work without the environment variable, like the old winavr
mattallen37
Okay, so I changed the Make and Program tools to use the make.exe program in the "C:\Program Files (x86)\Arduino\Arduino ERW 1.0.1i\hardware\tools\avr\utils\bin" directory. The Program tool was complaining with error 1 (which it has done a zillion times in my attempts to get things working again). It seems that the avrdude.exe in "C:\Program Files (x86)\Arduino\Arduino ERW 1.0.1i\hardware\tools\avr\bin" is actually not avrdude.exe, but perhaps a wrapper? avrdude2.exe is apparently what I need, so I renamed both of them, so that avrdude2 is now avrdude, and avrdude is now something it won't recognize.
Now WinAVR seems to be working (I can compile and download a program to an AtTiny85), and the Enhanced Arduino IDE still seems to download code properly to an UNO. I haven't tried much more than that so far.
Thanks for helping me out. I'll report back if I start seeing errors.
BTW, what's the deal with avrdude plus avrdude2?
eried
It is a wrapper as you said :)
Exactly what it does is:
https://github.com/eried/Arduino/blob/master/erw/csharp/AvrDudeReset/Program.cs
So when you call avrdude, it tries to open the com port first, otherwise calls the "fixer" (to disable/enable the non working device).
I use the IDE to program my tinys (copy hex as path) and khazama avr programmer to upload the code.
guix
Hello and thank you for this cool enhanced IDE, I'm using it since few weeks without problems :)
I have a small suggestion (sorry if it has been asked already) when we click "New" or open any sketch, it open it in a new window, it would be nice if it opened in a new tab instead :)
eried
Hehehe :D but I guess you don't understand how tabs works, they are not sketches, are part of the main sketch, like "subroutines". Look:
There are all the same "sketch".
eried
I've noticed some strange behavior in tab navigating.  When I first open the ide and use the keyboard shortcur (CNTRL + ALT + Arrow) for moving between tabs, if jumps two tabs at a time (either direction you choose).
I was trying to fix this, but I can't replicate it. Can you record some quick screencast or something  with the issue? happens with the on screen keyboard too?
Anyone else is experiencing this?
guix
Ah ok I see :)
But isn't it possible that you create other tabs above the existing tabs?? The above tabs would be for differents sketches, like this for example:
[sketch1][sketch2][sketch3][sketch4]
[graphic][loop][setup]
I'm sick of all those windows :P
eried
Ah ok I see :)
Well, you know: it is software, so everything is doable; but due the actual architecture of the application it is not a trivial to do. If a lot of people want it (like the menu scroller), I can search for something, but personally I like how Win7 stacks the windows in one icon (I usually disable the tabs in any application besides a browser/im)
guix
